McCormick W4 won't run
   / McCormick W4 won't run #1
DanB53
Soo, Ontario
McCormick W4
I am trying to get my W4 going for the first time but it will only fire a few times then die. I cleaned the tank, sediment bowl, put a new screen on the sediment bowl, blew out the fuel line with compressed air, disassembled carb; put new jets, needle and seat, seals, and gaskets into it, put a new coil, distributer cap, rotor, plug wires, plugs, I've checked the point and spark plug gaps. The timing is a few degrees after TDC. I'm getting good blue spark and I'm getting fuel to the carb. It is a 6v system. If I put fuel down the cylinders it will run until it uses all of that fuel up then it will shoot fire out the exhaust and make a huge BANG. I can't figure out what else to check/do. I really need help figuring this one out. :confused:
   / McCormick W4 won't run #2
Seeing as you cleaned the fuel system from tank to carb., I'm assuming things may have been a tad cruddy. Where the fuel line attaches to the carb., did you remove the inlet screen fitting, and clean it also..?? A good spraying with a can of carb. cleaner usually cleans them right up. It's pretty fine screen, so be kinda' careful.
Can't remember if they have a plug in the bottom of the carb. If it does, you can remove, and see if you are getting fuel in the bowl. If not, either the inlet screen is plugged, or the float is stuck.
I did clean that screen with carb cleaner, and when I pull that plug I get plenty of fuel out, I really doubt it's the float. I guess the inlet might have got plugged again, but it seems like I get pretty good flow when I take the plug out of the bottom.
   / McCormick W4 won't run #4
Sounds like no fuel. Are you certain of the correct float setting? New needle and seat shouldn't be sticking, but possible? Keep at it - you're on the right track.
Jim
Jim
I triple checked the float setting. And I was really careful putting it back in. It could be the needle and seat I guess. But it is doubtable. I'm still doing my best to trouble shoot. I'll keep you guys posted on my progress.
   / McCormick W4 won't run #6
If you have fuel in the bowl, next I'd check the metering nozzle, #17 on the exoloded view of the carb I posted. It will need to be removed, and check the cross drilled holes, to see if they are plugged.
The metering nozzle is brand new. Before I put the carb on Monday I checked all of the passages and they were clear but i guess they might have become plugged. I'm wondering if the governer could be an issue? Does that effect anything to do with starting?
   / McCormick W4 won't run #9
If it runs close to the throttle setting when you put gas in the cylinders, I wouldn't think so. It should activate fully though when that fuel is used up, and calls for more fuel, when the rpm's drop.
Is the choke plate fully closing? If I hand crank mine, I usually set the choke full, then within 3-4 turns, they will pop. Depending on the temps., either partial choke when cooler, or full off if hot, and 99% of the time, they run on the next crank. If electrical starting, full choke, and after 3-4 revolutions, they will fire up.
Either a fuel blockage, or a vacuum leak bad enough not to be able to pull the fuel up.
   / McCormick W4 won't run #11
Loss of vacuum could be valves not seating properly, stuck rings or bad gasket around intake manifold. I would do a compression test to give a little more insight into the problem. With stuck rings you can put some Automatic Trans fluid in to free the rings. I am thinking its stuck rings.
I've got 0psi in #4. Judging by the posts you sent me to, it is a valve. But shouldn't it run on 3 cylinders still?
   / McCormick W4 won't run #13
Shouldn't it run on 3 cylinders still?
You could still have a manifold leak internally from the intake to exhaust system at the heat chamber, or a external at the manifold where it meets the block. It shouldn't be a manifold to carb leak because of the new gasket in there.
   / McCormick W4 won't run #14
Sounds like #4 exhaust hanging open. That would explain the bang, when it runs out of gas. Hopefully the push rod just dropped out of the rocker arm when the valve stuck, and did not bend the push rod. Seems one of the other three should at least give a little poof, if getting fuel, and valves half way decent.
Had this tractor been sitting a while..?? From the looks of the picture in your avitar, looks like it was just painted/restored..?? Was it that way when you bought it? Just wondering if maybe the manifold to gasket was about shot, then a clean up with a power washer, or steam jenny took away what was sealing it.
It sat from the early 70s until last year when it was pull started and ran for an hour by the guy I bought it from. That is as long as it has run since the 70s. He just did a quick paint job to make it look a little nicer but that was all he did other than an oil change. I've done the only mechanical work since it was parked 40 years ago. If fixing the valve doesn't help I will pull the manifold. I haven't done any powerwashing or anything like that to it.
   / McCormick W4 won't run #16
Could be the valve stuck after he had it running too. And if cleaned for the paint job, may have unsealed an old intake gasket.
After removing the valve cover may tell you something too. Believe I'd check to see if oil is getting to the valve train, especially that end the valve hung up on.
Keep us posted..!!
P1040296.jpgHere is a pic of what it looks like under the valve cover. There seems to be plenty of oil spread over everything. It is the exhaust valve on #4 that is stuck. Nothing seems to be broken or bent. What is the best thing I can put on it to free it up? I don't have any Marvel Mystery Oil but what else would work? Also there is a hole on the top of what seems like the oil dispersal tube near the end closest to the rad. Can anyone conferm that it should be there?
I got the exhaust valve free. The intake was leaking slighly too. I did the leak test with compressed air on all 4 cylinders and all is good exept the exhaust on #4 isn't seating properly still. I got the compression up to about 70lbs on #4 but no matter what I try I can't get the exhaust to seat any better. I think once I get it running and rev it a few times it should knock the carbon build up thats holding it open out. But judging by what it looks like under the valve cover, I will go buy some Marvel Mystery Oil and mix a quart of that into the oil for the next couple oil changes to clean everything up.
   / McCormick W4 won't run #19
Could be that #4 exhaust is burnt too. Could have been hanging open slightly for a while, and burned. Possibly carboned up the stem and guide enough, it finally hung open. Moisture got, or is definitely getting in under the valve cover.
If it were mine, I'd pull that rocker assy. and clean it up outside the engine, but that's me...
And are my eyes deceiving me, or does the couple of spots/puddles of oil look milky..??
Your eyes don't decieve you. There was a fair bit of water in there and red paint for that matter. The gasket is toast and let moisture and the new paint under the cover. I think the water just seeped in through the gasket when I flushed the coolant passages in the block via the thermostat housing, I didn't see any water when I did the oil change when I first got it. I definitely will tear into the engine but I would like to get it fired up to see what all is wrong first. I cleaned the rocker assembly quite a bit, in place.
UNUSED FUTURE 72PRO-72" MULCHER (A60432)
UNUSED FUTURE...
2014 Chevrolet Impala Sedan (A59231)
2014 Chevrolet...
159118 (A60430)
159118 (A60430)
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A60430)
UNUSED I/A F10...
2025 32in Bucket Mini Skid Steer Attachment (A59228)
2025 32in Bucket...
2019 Bobcat T590 Compact Track Loader Skid Steer (A59228)
2019 Bobcat T590...
