chopped
Hello all,
I have a question and my opinion and would like to share it with anyone who has a responce.
My ptoblem was alot of air in my water stream in the mornings, This will be an artesian well, 130 foot deep, and pump set at about 120 feet.One inch line from a submersable pump.Pitless adapter and all using one inch black well pipe, double clamps at all connections.of cource a check valve in the pump, which is about 12 years old. the whole system is in 1980.
Ok, so I did up the pitless adater end and replace it with a new one.The older style had a leatehr gasket ,where the new one has an 'o' ring.It was apparent it wa leaking at the inside of the adapter as I could see slight bubbles and moisture at the fitting when it was pumping.So its all been replaced.And it has been ok for about a week or week and half.
Now Im getting slightly more air int he system overnight.:thumbdown:
anyways my thought now is that maybe the insdie check valve is also weak and is allowing more water than 'normal' or allowing less hold back of the water and the check valve itself is at fault also.
????? opinions?
The check valve isnt to difficult to change out so I think thta will be my next step .
Thanks..eveyone..
????? opinions?
Thanks..eveyone..
