RoyJackson
Rest in Peace
- Joined
- Nov 17, 2001
- Messages
- 23,144
- Location
- Bethel, Vermont
- Tractor
- John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
Thanks much to those with the useful advice, specifically the anti-scalp roller. I'll try to find one and add it to the mower to save the lawn.
I'll just start using the wheels like a mower is supposed to be used, and if I break off a wheel then it will probably be time for a new mower deck and I'll hopefully know a lot more about what I'm looking for by then. I don't know if the wilfe will like the expensive red lawn ornament though if that time comes.....
Ask your dealer...most RFMs have them as optional equipment. If not, there's not much to them. Odds are, you can find one that won't require too much modification.
As far as using the RFM...yep, do that. Just keep the spindles (the wheels pivot on vertical spindles) greased and keep an eye on them...if you see a weld cracking, you can fix it before it fails completely.
