Running RFM on the PTO vs wheels
   / Running RFM on the PTO vs wheels #21
Thanks much to those with the useful advice, specifically the anti-scalp roller. I'll try to find one and add it to the mower to save the lawn.
I'll just start using the wheels like a mower is supposed to be used, and if I break off a wheel then it will probably be time for a new mower deck and I'll hopefully know a lot more about what I'm looking for by then. I don't know if the wilfe will like the expensive red lawn ornament though if that time comes.....
Ask your dealer...most RFMs have them as optional equipment. If not, there's not much to them. Odds are, you can find one that won't require too much modification.
As far as using the RFM...yep, do that. Just keep the spindles (the wheels pivot on vertical spindles) greased and keep an eye on them...if you see a weld cracking, you can fix it before it fails completely.
   / Running RFM on the PTO vs wheels #22
The dealer I bought from has been in business over 50 years and has been selling Mahiindra for 12, it's a family operation with long-time roots in the area so I thought I had 'vetted' them properly. I also thought the fact that they had shopped around and found a better deal on accessories like the mower deck than just selling Mahindra was a good thing, but this is a learning process so I'll take it as an expensive lesson learned. I'll just start using the wheels like a mower is supposed to be used, and if I break off a wheel then it will probably be time for a new mower deck and I'll hopefully know a lot more about what I'm looking for by then. I don't know if the wilfe will like the expensive red lawn ornament though if that time comes.....
You should be okay with your finish mower, it should last for quite a few years and if something breaks it probably can be fixed. Did your dealer check to make sure the PTO shaft is the proper length?
   / Running RFM on the PTO vs wheels #23
He probably did, and that is why he told him run it with the mower up, because when
its down there is not enough engagement in the shaft 'cause it's cut a tad short. :)
   / Running RFM on the PTO vs wheels #24
now that sounds about the right speed from what we have heard so far! ;)
   / Running RFM on the PTO vs wheels #26
Can TBN publish a list of acronyms?
TBN is TractorByNet BTW
Not a bad idea...and make it a sticky
couple to start:
FEL: Front End Loader
MMM: Mid Mount Mower (belly mower)
   / Running RFM on the PTO vs wheels #27
What is BTW?
   / Running RFM on the PTO vs wheels #29
There are way too many to post here, but this is a link for internet acronyms:
Internet Acronyms Dictionary
I haven't gone through the list, so be advised some might be uncouth and vulgar (sorta like me, but without the hat).
   / Running RFM on the PTO vs wheels #30
94BULLITT said:
By the way
I was only kidding. But thanks, btw. lol
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2003 John Deere 310SG (A47477)
2003 John Deere...
2014 Ford F-150 Ext. Cab Pickup Truck (A52377)
2014 Ford F-150...
