What's wrong with homemade sand gravel charcoal filtering thru 2 staggered 5 gal buckets total cost less than $10.00 and if you feel unsafe with that boil it after filtering.
I will post a link to a gentleman who has posted why sand/charcoal is not recommended for water purification.
Homemade water filter using materials from Walmart and other giant retailers - Survivalist Forum
look for the posts by stephpd but here is some of the pointers.
And though the folks that sell biosand filters would like you to believe that you can shortcut the laws of physics. In that they would like you to believe that you can get quality water out of a very small slow sand filter.
There's a reason they aren't used in this country and it has to do with not making even clear water. It may or may not kill bacteria and viruses. But without an extensive lab you have no way of knowing.
Best bet would be to stock up on a lifetime of filters before TSHTF. Ceramic filters are readily available, clean the water sufficiently and aren't very expensive. There downside is they have a limited use of only a few thousand gallons.
Abetter bet would be to purchase a few membrane filters. They cost a bit more but can filter far more water and to a lower turbidity. Sawyer makes several moidels to choose from. BUt thier basic filters break down to the .1 and .02 micron filters. They fit in the palm of your hand and can filter at least a million gallons if they don't get broken. And the .1 costs less then $50.
That one filter a couple buckets and a couple pounds of calcium hypochlorite would make water for you and your family for the rest of your life. And not cost more then $100 today.
Boiling will kill bacteria and viruses but not much else.Lots of bad things can still be in boiled water.
I first started making water 35 years ago in the Navy. It was a two stage evaporator (distiller). And it not only took lots of fuel to make the steam used but also lots of electricity to run pumps to have a steady and rather limited supply. It was also the cleanest water I've ever made and we still disinfected the water with bromine. Chlorine being a bad thing around a steel ship and the subsequent corrosion.
And there were times when they just wouldn't make clean water, like when we got near land. Seems the water near land was too polluted to make distilled water. On occasion we'd pull into port and would draw a sample of the water provided at the pier and they'd not have any measurable levels of chlorine and we couldn't hook up. Then we'd have to anchor out to continue to make water and take fairies to shuttle folks back and forth.
Same for your idea of just using sand and charcoal. I know that doesn't work because I have to shut down the filter plant when I loose the coagulant. I constantly monitor and test the water I make and I know this won't fly.
And in the last 3 days I've personally made over 30 million gallons of potable water far below the Federal standards. In the last 5 years I've made over 5 billion gallons of potable water. So I think I know what it takes to make water by pouring it through sand and charcoal.
At a minimum you'll need some way to make a floc in a drum. Decant the water from the middle portion and then use that water in a sand filter. But you'll still need to disinfect it too. That can be done by SODIS in small batches.
You'll also need a way to somehow backwash the filter on a regular basis. And waste the floc that settles too. As well as any scum that floats in the drum.
All said and done and you'll still be spending more then the $100 for the two things I recommend. Properly cared for the Sawyer can make at least 1 million gallons of water. Not forever, but well more then a family needs in a lifetime.
Thanks for the info. I use a two filter systems with UV (last in the line) run off my PV. I haven't had the water tested lately but it's pretty good. I could go to a three or four filter system before the UV but I haven't had any problems and our water taste very good. We do keep squeeze bottles around for our BOB.
