What fuel mileage are you getting?
   / What fuel mileage are you getting? #21
08 6.4L Ford F250 w/ a lot of work done to it.
35in Good year Duratrac's, Extra springs in the rear, 3.73 rear end w/ Detroit Tru-Trac locker
15-17 mpg city, up to 22-24mpg High way.
With the 24ft goose neck on, depending the the load 12-15.
   / What fuel mileage are you getting? #22
13mpg at 65mph sounds like it's running good. Remember the bad old days in the 1970's were the same sized vehicle at that speed would do 4-5 mpg.
   / What fuel mileage are you getting? #23
Here is the link to its rating on the epa site, unfortunately they don't have a 4WD listed. It is 15MPG combined for a 2WD.
Compare Side-by-Side
How do I check cat converters?
I think it should be doing better. It has the 5.4 with a 6 speed trany. Other say they are getting 18-20 mpgs by the computer, well I'm measuring the same way.
   / What fuel mileage are you getting? #25
I have a 2003 F-350 4x4 with crew cab 4-door long wheel base with the 6.0 diesel,, bought it new,, had the bully dog chip installed when I got it,, 60 or 130 horses more,, I get without trailer,, at 70 mph 21.9mpg,, with trailer 17.6 mpg loaded,, in town around 14 mpg but I leave it running if it going to be 15 minutes or less,, most times it more.. I have 93K miles on it.. I only use it for ranch use,, I have it servesed once a year.. Lou
   / What fuel mileage are you getting? #26
Your mileage is fine for that vehicle. If you had a clogged cat you would be low on power which you said you had plenty of power and you may have a check engine light.
   / What fuel mileage are you getting? #27
My 93' Jeep Cherokee Sport gets about 15-18 mpg.
   / What fuel mileage are you getting? #28
Lou, I have the same truck but a 06. I get about the same as you. 21.6 mpg on the highway and 17 mpg just about every tank. It has a Quadzilla 60/120 HP chip, MAC Intake, and 4" exhaust. I never let it idle. Towing my big boat, 15,600# I get right at 15.5 mpg.
I also have a 08 Nissan Titan. It gets about mid 16's on the highway and about 14mpg average tank to tank. Towing is between 8.5 with 9,700# behind it and with just my car hauler and it loaded it will do just shy of 12mpg.
Chris
   / What fuel mileage are you getting? #29
Chris
   / What fuel mileage are you getting? #30
Chris: My wife drives a 2007 jeep wangler hard top two door, we bought it new in 2007, with all the bells and whistles,, it gets around 15 mpg from tank to tank if I am lucky,, tried to get her to trade it off or just get something else to drive,, but it not going to happen.. Lou
1991 HEIL FUEL TRANSPORT TRAILER (A52472)
1991 HEIL FUEL...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2011 GLOBAL 130BBL VAC TRAILER (A52472)
2011 GLOBAL 130BBL...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
2017 TAKEUCHI TB240 EXCAVATOR (A51246)
2017 TAKEUCHI...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
