is there any way to slow down a DC motor?
   / is there any way to slow down a DC motor? #31
You could try a 12v headlight or work light in series.... Just to see what it does...
   / is there any way to slow down a DC motor? #32
Good idea but foiled by avalanching resistance as the filament heats. Inrush to an incandescent is huge and might twitch the motor, but current would quickly drop way below whats needed.
OP a long piece of fairly small ~ 18ga copper wire wound on a hunk of fiberglas would do it for you. I think about 30' +/-. Try not to overlap.
larry
   / is there any way to slow down a DC motor? #33
I did much the same thing but used a small Bosch starter motor. Spent a lot of time separating the field and armature windings hoping to reduce speed and/or change directions. Next plan used power seat motors from mini van. Finally switched to hydraulic motor from scrap salt slinger. A smaller starter motor might have worked with separate 6 volt battery ....
   / is there any way to slow down a DC motor? #35
Far too many ohms. The wattage is rated using the whole resistor therefore it derates as you turn the resistance down.
   / is there any way to slow down a DC motor? #36
What he said. How much current does this winch pull?
   / is there any way to slow down a DC motor? #38
   / is there any way to slow down a DC motor? #39
Older elevator motors are DC and they are variable speed. You just need the proper design motor and vary the voltage.
2018 Mac 48ft T/A Walking Floor Trailer (A51692)
2018 Mac 48ft T/A...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A52377)
2021 Fleco DX140...
