is there any way to slow down a DC motor?
   / is there any way to slow down a DC motor? #31
You could try a 12v headlight or work light in series.... Just to see what it does...
   / is there any way to slow down a DC motor? #32
Good idea but foiled by avalanching resistance as the filament heats. Inrush to an incandescent is huge and might twitch the motor, but current would quickly drop way below whats needed.
OP a long piece of fairly small ~ 18ga copper wire wound on a hunk of fiberglas would do it for you. I think about 30' +/-. Try not to overlap.
larry
   / is there any way to slow down a DC motor? #33
I did much the same thing but used a small Bosch starter motor. Spent a lot of time separating the field and armature windings hoping to reduce speed and/or change directions. Next plan used power seat motors from mini van. Finally switched to hydraulic motor from scrap salt slinger. A smaller starter motor might have worked with separate 6 volt battery ....
   / is there any way to slow down a DC motor? #35
Far too many ohms. The wattage is rated using the whole resistor therefore it derates as you turn the resistance down.
   / is there any way to slow down a DC motor? #36
What he said. How much current does this winch pull?
   / is there any way to slow down a DC motor? #38
   / is there any way to slow down a DC motor? #39
Older elevator motors are DC and they are variable speed. You just need the proper design motor and vary the voltage.
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
1996 Ingersoll-Rand VR642C (A47477)
1996...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
2013John Deere 244J (A47477)
2013John Deere...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
