Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #271
You could add, 2x4s flat on wall as spacers for your track mounts, to allow the addition of 1.5" more foam. I wolud go for the added R-value.
Dave
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #272
Do you know the ratings for the torsion springs you want to use? The reason I'm asking is that when I built the overhead door for the garage/shop I built years ago when I lived in Winnipeg, it turned out really well - but shockingly heavy. The springs I had scrounged (remember, I'm a proud cheapskate!) were off a much lighter door. It had been a 9'x11' aluminum overhead. What I built was a 9'x16' wood with Styrofoam inserts. I don't know what the aluminum door weighed but not nearly the 600 or so pounds that wooden one did! You wanna guess how fast I found out how much I didn't know what I was doing?:ashamed:
Knowing how thoroughly you plan things, you probably have made allowance for this...but just in case.:eek:
I calculated the weight based on lumber weight tables. Then I had a garage door guy help me with all the hardware. He gave me two sizes of springs so that I'm more likely to have one that works.
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #274
Ahh!:thumbsup: I was right about how you plan carefully. That shop is looking better all the time.:cool2:
Thanks.
I cut out the frame for my garage door. I've decided to go with 1.5" for now. If I find that the area around the door is too cold I can make a thicker door later.
Here's the foam core.
Does anyone have any suggestion on how to cut styrofoam? I've tried a few things and ended up with a serrated kitchen knife.
   / Root Cellar Remodel, Split Level Storage, Shop, Shed Pole Building on a Foundation #278
I like to use a regular hand saw to cut styrofoam.
Eddie
Thanks, Eddie. I may try that. The kitchen knife cuts okay, it just leaves a rough edge and gets fluff all over the place.
Here's a picture of the top panel done.
Oops... Here's the picture.
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
New Holland 650 Hay Baler (A53317)
New Holland 650...
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2016 FREIGHTLINER...
