I Just Destroyed My Optima Yellow Top...
   / I Just Destroyed My Optima Yellow Top...
wrooster said:
By the way, there is one more clue here: a car made in 2008 should not be going on it's third battery... that is pointing to a separate problem altogether.
Wrooster
The car was owned by a police department before I got it. It has 132,000 miles and probably 10000+ hours by now.
You guys were right. The wire leading from the fusible link to the harness is shorted to ground somewhere. I used a paper clip and my continuity tester to check every fuse and relay connection for grounding. The terminals marked in red in the photo are shorted to ground.
   / I Just Destroyed My Optima Yellow Top... #13
makes me wonder too. with proper filtering.. you can have an output from a line source LOOK like dure DC on a scope, for a given load. heck.. you could charge pump it and not know.
makes ya wonder...
rapid recharge seems to contradict that too...
That makes no sense. How and why does the battery react differently depending on whether it is connected to an alternator-powered charging system versus a utility-powered charging system? If I stuck two wires through a wall, and there was nominal charging voltage on those wires (say 13.8Vdc), you'd have a hard time telling me whether the power was being sourced by an alternator or a charger.
Any way you charge the battery, as the state-of-charge increases towards 100% the battery terminal voltage increases and accordingly the charging current will decrease -- and therefore the entire charging process is self-limiting.
Wrooster
   / I Just Destroyed My Optima Yellow Top... #14
my o4 f250 has more miles on it.. has been driven by a dozen people.. and is on it's 2nd 'set' of batteries.
an 08 with that many changes? makes me wonder.
does it have the high capaity alt on it? ( extra load of light bars..e tc..e tc.. ) or was it dewatt'ed??
   / I Just Destroyed My Optima Yellow Top... #15
Wrooster
They are concerned that the batt charger may not taper off like most do. 10A for 12hr would be an overcharge. Alt V reg has a healthy charge regimen built in. ... and they dont do extended hi A charging.
larry
It has the larger 150 amp alternator.
My cousin has a 2000 F250 7.3L and his original batteries lasted 10 years.
   / I Just Destroyed My Optima Yellow Top... #17
larry
any unloaded-clamped or regulated bat charger should be no issue for it.. especially one of the smart units.
from what you are saying.. they just have some dumbed down CYA directions on it that are meant as a safety net mostly, and otherwise prevent 60% of the 'good' chargers out there from being used. :)
I can understand that. I've built plenty of stuff that I left CYA instructions on use for.. since I didn't know how smart / dumb the user was gonna be. :) :)
   / I Just Destroyed My Optima Yellow Top... #18
They are concerned that the batt charger may not taper off like most do. 10A for 12hr would be an overcharge. Alt V reg has a healthy charge regimen built in. ... and they dont do extended hi A charging.larry
And exactly how does the battery charger keep supplying 10A as the terminal voltage of the battery approaches the charger's setpoint voltage?
Wrooster
   / I Just Destroyed My Optima Yellow Top... #19
Wrooster
i can see a old transforer and rectifier only setup, that had a extremely high open circuit voltage.. perhaps in the 25v range.. and a lightly loaded circuit voltage of say.. 17-19v, boiling a battery at 15+v and still sinking some significant current... but those designs that use hi circuit voltages to achieve high current rates when the bat is low are getting exceedingly rare. even the china store stuff turned out has taken steps to prevent this with very very simple clamping circuitry and better targeted to load transformers.. not something off the shelf that was made to fit.
even my old 2-10-50 sears from 20+ years ago, once a LA battery is at 15v on the posts, the output on the 10a setting is around 3.5 and on th 50a boost.. it's less than 10a and that's a low duty cycle setting..e tc..
optima is just doing a cya in case someone whips out a bat charger from 1920 or hooks up a variac and a big hunk of silicon to it. E.. they are planning for the 1%
the chinese roll around 200a starter / charger I have is even pretty well behaved on open circuit voltage protection and charge rate at duration.... and lets face it. it's hard to get any more questionable than china.. I don't think india, north korea or africa is exporting any bat chargers currently. those I might wonder about.. :)
   / I Just Destroyed My Optima Yellow Top... #20
10 years... I'm doing good to get 3.
2025 Swict 78in Bucket Skid Steer Attachment (A55851)
2025 Swict 78in...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
Informational Lot - Financing (A55315)
Informational Lot...
Golf Cart (A55787)
Golf Cart (A55787)
2017 Kubota M7-151 Premium MFWD Tractor (A55314)
2017 Kubota M7-151...
EZ-GO Electric Utility Cart (A55853)
EZ-GO Electric...
