How to get gravel out of pipe?
   / How to get gravel out of pipe? #11
When I had my pool built they got gravel in the pvc pipe and used shop vac to get it out
Then there's the high pressure air hose...be sure to wear your safety glasses!
   / How to get gravel out of pipe? #12
Shopvac, air pressure, water jets,, come on men the only real way to get that gravel out is to take six steps to the east tunnel down 6 ft. then tunnel west for 8 ft. given yourself plenty of room to tunnel up.. 2ft and 2 inches,, climb out of the tunnel .. go back to the plugged pvc door rebar holder and attach a 750 mobile air diesel compressor with full 2 inch reduced to ¾ inch hook up. When the pressure builds to 175 psig throw the 90 degree valve wide open forcing the gravel from the pipe into the tunnel.. Shutdown and Disconnect the air blaster piping and check for rock removable,, back fill the tunnel,, job complete,, also I could come up with a plans for some explosives,, let me know.. Lou
   / How to get gravel out of pipe? #14
How about bubblegum on a stick? Get it out one rock at a time. Great job for a guilty 3yo.
   / How to get gravel out of pipe? #15
You might find some sort of adhesive (something really sticky like pine tar etc.) and a stick and lift them out one at a time...
   / How to get gravel out of pipe? #16
When I was younger, I used to help a friend of mine who had a Stucco business. On one job, the drywall crew got mad at the electricians and put marbles in the electrical PVC pipe. The electrical crew just attached a Shop Vac to the pipe, sealed the connection with duct tape to provide a better vacuum, and all the marbles came out.
   / How to get gravel out of pipe? #17
The problem with using a vacuum is (to be effective) there needs to be a source of air with enough volume underneath to lift the stones
Hence my idea of reducing it to a 1/2" OD pipe...
Aaron Z
   / How to get gravel out of pipe? #18
Aaron Z
Sorry, I did not read every reply suggesting vacuum thoroughly...you made a viable suggestion that would probably work...
   / How to get gravel out of pipe? #19
reverse the setup
solid bar in the ground with the pipe on the door.
Fix it right.
   / How to get gravel out of pipe? #20
reverse the setup
Fix it right.
The OP did not state where the "pipe" is in relation to the door opening...if it's wide open and against the wall that would be OK but IMO the pipe in the ground just barely above flush with grade is the safest application...rebars sticking up create a hazard just about anywhere...JMO
2001 Pierce Spartan Model Tilt Pumper Fire Truck (A59230)
2001 Pierce...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2005 Cheverolet 2500 Pick Up Truck (A59814)
2005 Cheverolet...
2024 CATERPILLAR 255 SKID STEER (A60429)
2024 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 DRAGON ESP...
