How to get gravel out of pipe?
   / How to get gravel out of pipe? #21
The OP did not state where the "pipe" is in relation to the door opening...if it's wide open and against the wall that would be OK but IMO the pipe in the ground just barely above flush with grade is the safest application...rebars sticking up create a hazard just about anywhere...JMO
true enough
if the pipe is out in a grass area with a wheel guide next to the building he is trying to stop just the outer end of the door from sailing.
in that case a larger o.d. pipe in the ground that a shop vac hose could fit into would be another good fix.
pitures tell the story
   / How to get gravel out of pipe? #22
ditto....may need to experiment with different sized nozzles, perhaps temporary made for the purpose, so it will pick up the rocks...amazing what a shop vac will do. I use it for reaching the bottom of post holes and cleaning them out when my arm gets too short.
How about a shop vac.
   / How to get gravel out of pipe? #23
Pilot said:
So how to get crushed 3/4 minus gravel out of this pipe?
21Bg8q2UqlL.jpg :)
Amazon.
   / How to get gravel out of pipe? #25
   / How to get gravel out of pipe? #26
Post hole digger with 1/2 inch auger.
Bruce
Now we have gone full circle, and we're back to my suggestion.
Hammer drill with a long 1/2" bit. :thumbsup:
   / How to get gravel out of pipe? #27
Agreed the shop vac should do the job. I would go with that clear tubing they sell at the hardware store. Duct Tape it to the end of the end of the hose and Ta-Da a portable flexible suction unit that would put any unit in the Emergency room to shame.
You could also probably try a blow gun and put a piece of copper tubing on the end of it with a large air compressor. Wiggle it down below the rocks and force them out with compressed air.
   / How to get gravel out of pipe? #28
I've cleared shavings out of deep holes before by using a shop vac and compressed air. I took a vacuum nozzle and drilled a 3/16" hole in it. I also got a piece of brake line and attached it to a blow gun. You put the nozzle over the hole (pipe in your case). Then stick the brake line through the small hole and down as far as you can. Hit the trigger and the stuff in the hole will shift around while the vac sucks it up.
OP here. Some good suggestions. I had a shop vac at the hangar (originally didn't expect it to work since there is no air flow thru the pipe) and it sucked out the top 6" of gravel. Still have several inches to go, but I think the idea of using a small tube of some sort attached to the shop vac hose with duct tape will do the rest.
   / How to get gravel out of pipe? #30
Don't forget Pilot,, if the shop vac doesn't take care of the problem,, I can still come up with some type of explosive device with the use of a tractor front end loader as a shield,, if needed.. just let me know.. Lou
1959 DODGE D510 DUALLY FLATBED TRUCK (A60430)
1959 DODGE D510...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
207275 (A52708)
207275 (A52708)
2024 MECO M-Y 4-Passenger Electric Car (A59231)
2024 MECO M-Y...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
