I Just Destroyed My Optima Yellow Top...
   / I Just Destroyed My Optima Yellow Top...
I am 99% sure the Optima is good. I charged it overnight using a 6 amp charger. The first four hours showed a 4 amp rate and the when I checked it this morning, the needle was at zero amps. Voltage is now stable at 12.82V.
Won't be putting it back in the car until I find the short.
   / I Just Destroyed My Optima Yellow Top... #33
Thanks for the update and you found the outcome we expected. As long as that battery is charged a couple times a year even is sitting over in the corner on concrete should be good years later. :) A battery with a shorted cell will max out at 10.5-11v.
I have found with a 6 amp manual charger if the rate will drop below 1 amp overnight the battery is healthy.
   / I Just Destroyed My Optima Yellow Top... #34
check it in a few hours.. if it holds at 12.6 or so, and don't drop in a day.. I'd say it dodged a bullet.. :)
I threw the battery in a snow bank and left it for a couple days. I had to chisel an inch of ice to get at the terminals today and it's holding at 12.62 V.
   / I Just Destroyed My Optima Yellow Top... #36
Sounds like you are good to go with the battery! CJ
   / I Just Destroyed My Optima Yellow Top... #37
i guess so!
Update: The problem turned out to be a wire running to the Special Equipment Option (SEO) fuse block under the dash was rubbing on a metal brace. My continuity tester was giving me false positives and leading me to think a bunch of other stuff was shorted. The car is back on the road and everything is working great (including the Optima).
   / I Just Destroyed My Optima Yellow Top... #39
Thanks for this follow up post. Glad the results were positive.
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
401 (A52706)
401 (A52706)
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
JOHN DEERE 2155 TRACTOR (A52708)
JOHN DEERE 2155...
New/Unused 72inch Quick Attach Vibratory Roller (A57454)
New/Unused 72inch...
