I Just Destroyed My Optima Yellow Top...
   / I Just Destroyed My Optima Yellow Top...
I am 99% sure the Optima is good. I charged it overnight using a 6 amp charger. The first four hours showed a 4 amp rate and the when I checked it this morning, the needle was at zero amps. Voltage is now stable at 12.82V.
Won't be putting it back in the car until I find the short.
   / I Just Destroyed My Optima Yellow Top... #33
Thanks for the update and you found the outcome we expected. As long as that battery is charged a couple times a year even is sitting over in the corner on concrete should be good years later. :) A battery with a shorted cell will max out at 10.5-11v.
I have found with a 6 amp manual charger if the rate will drop below 1 amp overnight the battery is healthy.
   / I Just Destroyed My Optima Yellow Top... #34
check it in a few hours.. if it holds at 12.6 or so, and don't drop in a day.. I'd say it dodged a bullet.. :)
I threw the battery in a snow bank and left it for a couple days. I had to chisel an inch of ice to get at the terminals today and it's holding at 12.62 V.
   / I Just Destroyed My Optima Yellow Top... #36
Sounds like you are good to go with the battery! CJ
   / I Just Destroyed My Optima Yellow Top... #37
i guess so!
Update: The problem turned out to be a wire running to the Special Equipment Option (SEO) fuse block under the dash was rubbing on a metal brace. My continuity tester was giving me false positives and leading me to think a bunch of other stuff was shorted. The car is back on the road and everything is working great (including the Optima).
   / I Just Destroyed My Optima Yellow Top... #39
Thanks for this follow up post. Glad the results were positive.
YAMAHA OUTBOARD MOTOR (A58374)
YAMAHA OUTBOARD...
2016 Kawasaki Mule KAF620S 4x4 Utility Cart (A55973)
2016 Kawasaki Mule...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
2010 Chevrolet Tahoe SUV (A56859)
2010 Chevrolet...
2010 BMW 328i (A56859)
