Wanting to mount some lights to loader?
   / Wanting to mount some lights to loader? #21
Neat setup scooby and well done. My only problem is that I would either need to go nuts with the pruners to get rid of tree branches or I would need to keep a few extra lights and brackets on hand. I already keep an extra lens or two for my hazard and tail lights as tree branches seem to collect them. LOL
You could move them in closer to the ROPS and/or go with a fully magnetic mount. If you accidentally hit something the light would break away. Or make them rigid mounts and add some guarding?
I know one thing, once you add some aux lights you will never go back.
One more option. Kubota is going to be making a factory kit to add aux lights to the BX mounted to the fender. Might be adaptable to your tractor or you could build something similar????
   / Wanting to mount some lights to loader? #22
Here's where i mounted my B7800 lawnmower lights. Low to the ground keeps the shadows down and I can see better.
ATTACH=CONFIG]293267[/ATTACH]001.JPG
   / Wanting to mount some lights to loader? #24
When operating after dark, I like to have lighting both out front and to the sides. Lights mounted on the ROPS does that and the lights mounted toward the rear of the FEL frame worked pretty well. Mounting lights on the brush guard wouldn't light things up enough for me.
   / Wanting to mount some lights to loader? #25
Nothing fancy here, but it does work with the bucket and plow. Turns out that the snowblower chute is directly in line with one of the lamps. I used some angle aluminum stock I had around and bolted the stuff to the support frame of the tractor. To remove the FEL I have to disconnect the cross arm support so as to miss the lights. Prior Planing would have prevent poor performance. I guess. LOL
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
1992 Pine 53ft. T/A Dry Van Trailer (A55852)
1992 Pine 53ft...
2005 Interstate 7x14 Trailer (A55973)
2005 Interstate...
2021 International MV607 S/A Dump Truck (A55852)
2021 International...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A55852)
2003 Pierce Tilt...
