Wanting to mount some lights to loader?
   / Wanting to mount some lights to loader? #21
Neat setup scooby and well done. My only problem is that I would either need to go nuts with the pruners to get rid of tree branches or I would need to keep a few extra lights and brackets on hand. I already keep an extra lens or two for my hazard and tail lights as tree branches seem to collect them. LOL
You could move them in closer to the ROPS and/or go with a fully magnetic mount. If you accidentally hit something the light would break away. Or make them rigid mounts and add some guarding?
I know one thing, once you add some aux lights you will never go back.
One more option. Kubota is going to be making a factory kit to add aux lights to the BX mounted to the fender. Might be adaptable to your tractor or you could build something similar????
   / Wanting to mount some lights to loader? #22
Here's where i mounted my B7800 lawnmower lights. Low to the ground keeps the shadows down and I can see better.
ATTACH=CONFIG]293267[/ATTACH]001.JPG
   / Wanting to mount some lights to loader? #24
When operating after dark, I like to have lighting both out front and to the sides. Lights mounted on the ROPS does that and the lights mounted toward the rear of the FEL frame worked pretty well. Mounting lights on the brush guard wouldn't light things up enough for me.
   / Wanting to mount some lights to loader? #25
Nothing fancy here, but it does work with the bucket and plow. Turns out that the snowblower chute is directly in line with one of the lamps. I used some angle aluminum stock I had around and bolted the stuff to the support frame of the tractor. To remove the FEL I have to disconnect the cross arm support so as to miss the lights. Prior Planing would have prevent poor performance. I guess. LOL
2019 Dodge Charger (A56859)
2019 Dodge Charger...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
2013 International TerraStar Enclosed Service Truck with Liftgate (A56858)
2013 International...
2017 John Deere 1025R Tractor - 626 Engine Hours (A55315)
2017 John Deere...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
