Water tranfer tank -- horses
   / Water tranfer tank -- horses #11
I picked up a few of those 15gal barrels at the local hospital that laundry soap comes in. I just put a spicket in the small bung hole, 3/4in pipe I think, and attached a piece of garden hose. In the large 2in bung hole I mounted a valvestem and used my small emergency air pump to pressurize the tank. I mounted the small barrel on its side on a wooden skid fastening to it with some old rachetstrap material. To refill, I just screwed out the 2in barrel bung and stuck in the garden hose from the house. I suspect you could do the same thing with a larger barrel or even a 250gal tote. Safe air pressure was only about 15psi air pressure, over that and you risk splitting the barrel. Ask me how I know!!! Worked pretty good for watering the garden. My setup empty only weighs maybe 10lbs, so its easy to set in and out of my gator. The air pump I just connect to the cigarett port already on the gator.
   / Water tranfer tank -- horses #12
Get one of these. Or, just pound a well down to get water with a shallow well pump.
   / Water tranfer tank -- horses #14
We use 330gal IBC's in the bed of a 3/4 ton pickup. It has a two inch outlet. Purchased a flexible (not green) 2 " suction hose that stays flexible to -20f. We fill it from the irrigation ditches in summer and from the well during winter. Yesterday I filled it via out home water heater - need to be flushed anyway. Not sure what the net temp was at a 150 gal fill. Pretty warm filled two stock tanks yeaterday. Stayed at 25f most of the day and was 15f this am. Very thin layer of ice.
I have also ganged 10 of them together for an irrigation project last summer and pumped to springler heads with a 6hp 2" pump. Worth the purchase
   / Water tranfer tank -- horses #15
Thanks for the pictures
   / Water tranfer tank -- horses #18
Thanks Kyle. It works well, and I know it's overkill for the few times I actually use it; but I wanted to try my hand at building something more complex.
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A55301)
Gooseneck...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
2018 International Durastar 4300 Altec LR756 56ft. Insulated Forestry Chipper Bucket Truck (A55852)
2018 International...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
30in Forks and Frame Mini Skid Steer Attachment (A55851)
30in Forks and...
