Water tranfer tank -- horses
   / Water tranfer tank -- horses #11
I picked up a few of those 15gal barrels at the local hospital that laundry soap comes in. I just put a spicket in the small bung hole, 3/4in pipe I think, and attached a piece of garden hose. In the large 2in bung hole I mounted a valvestem and used my small emergency air pump to pressurize the tank. I mounted the small barrel on its side on a wooden skid fastening to it with some old rachetstrap material. To refill, I just screwed out the 2in barrel bung and stuck in the garden hose from the house. I suspect you could do the same thing with a larger barrel or even a 250gal tote. Safe air pressure was only about 15psi air pressure, over that and you risk splitting the barrel. Ask me how I know!!! Worked pretty good for watering the garden. My setup empty only weighs maybe 10lbs, so its easy to set in and out of my gator. The air pump I just connect to the cigarett port already on the gator.
   / Water tranfer tank -- horses #12
Get one of these. Or, just pound a well down to get water with a shallow well pump.
   / Water tranfer tank -- horses #14
We use 330gal IBC's in the bed of a 3/4 ton pickup. It has a two inch outlet. Purchased a flexible (not green) 2 " suction hose that stays flexible to -20f. We fill it from the irrigation ditches in summer and from the well during winter. Yesterday I filled it via out home water heater - need to be flushed anyway. Not sure what the net temp was at a 150 gal fill. Pretty warm filled two stock tanks yeaterday. Stayed at 25f most of the day and was 15f this am. Very thin layer of ice.
I have also ganged 10 of them together for an irrigation project last summer and pumped to springler heads with a 6hp 2" pump. Worth the purchase
   / Water tranfer tank -- horses #15
Thanks for the pictures
   / Water tranfer tank -- horses #18
Thanks Kyle. It works well, and I know it's overkill for the few times I actually use it; but I wanted to try my hand at building something more complex.
2016 Nissan Versa Sedan (A55853)
2016 Nissan Versa...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
2011 Ford Escape XLT SUV (A54815)
2011 Ford Escape...
2023 RTVXG-850 SideKick (A55314)
2023 RTVXG-850...
