Urgent, need security help
/ Urgent, need security help #81
A determined thief can and will get in to your property. You have two real solutions - get insurance for personal property and develop a plan for your wife and your personal defense while you are there. You will never keep out a determined thief
Your right. Nothing can stop a determined thief that absolutely wants to get to YOUR and only your property. A good gate, that's not easily defeated, usually causes the thief to go to the next, softer, target.
And for all, insurance is a must.
/ Urgent, need security help #82
Most thieves are lazy, the more obstacles you place in their way the better you keep them out. I like your ideas here, keep them coming.
/ Urgent, need security help #83
Lloyd_E said:
The pad lock in up inside a steel box(bottom open) you reach inside, unlock, remove lock and pull pin. The gate opens. The lock box is made from 1/2" plate and the pin is usually 1.5"+. I am no expert but I think the only way to get in with this set-up is to use oxy/acet torch.
Or they just step over it and go on foot. They can't haul much that way is all.
/ Urgent, need security help #85
As much as I LOVE the way you think masks can easily defeat camera pics.
I need to shore up the entrance so my wife can feel secure, if she's there alone.
Get a picture of their vehicle though. Began thinking on security
/ Urgent, need security help #87
Not all property is insurable, we tried which was one of the reasons we went through such detail to secure our stuff. The property I discussed in this and another thread was not insurable, I tried several agents and all said we had to have a residence associated with property to get it insured. We now have a residential farm policy that covers our remote properties as a part of our home property.
ilander is correct, my property is not insurable, I tried!
1bush, thank you for the link, good drawing of the gate. I finalized a gate concept, I'll use 2" schedule 40 steel for fabricating the door with 6" or 8" steel round pipe to hang and lock the door onto. I've also finalized on the locks, they will be the following:
Trimax THPXL "Hockey Puck" Internal Shackle Trailer Door Lock - Rekeyable : Amazon.com : Automotive
They'll work well on my conex container as well as the workshop and gate doors. I will post pics when the entrance has been completed. My next step is to concentrate on the elctronics portion of security......
/ Urgent, need security help #90
The 8" pipe gate or a draw bridge with sides protected from someone trying to bypass it.
Dog for when you are there, and cameras for when you are not.
I like the land mine idea.
Getting the utility to put a light and pole at the gate would be nice, even if you have to pay for it (the light). Having AC power available would increase your options, but then you need to harden your power lines against being cut or otherwise disconnected.
The ground has been drilled for the gate posts, they will now have to be cemented today or tomorrow.
But on a better note, yesterday was a wonderful day because we poured a cement pad into the barn, no more dust in the nostrils....
Putting big red to good use
Using equipment to haul everything up hill about 300 yards
Coming together
The gate posts have been cemented into place. As soon as the hinges arrive the gate fabrication will start and will be hopefully completed this weekend.
The cement barn pad is working out great, next thing will be to build a door for it 'cause if it's not the dust it's the leaves :)
/ Urgent, need security help #95
Thanks for posting the great pictures. It's good to see your determination and your progress.
/ Urgent, need security help #96
GCP. I take it your going for a horizontal swing, "forestry" gate? Good choice. Make sure you weld an enclosure that you have to reach up into, for the lock. It keeps it out of the weather and will slow down a crook a bit.
2015 CATERPILLAR 259D SKID STEER (A60429)
2015 CATERPILLAR...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
PALADIN GSS72-72" HYD BRUSH CUTTER (A60429)
PALADIN GSS72-72"...
2011 JLG E400AJP BOOM LIFT (A60429)
2011 JLG E400AJP...
ALAMO A84-84" HEAVY DUTY BRUSH CUTTER (A60430)
ALAMO A84-84"...
2020 SAVANA 3500 16FT BOX TRUCK (A59905)
2020 SAVANA 3500...
