Some end of the year snow blowing video with my loader mounted hydraulic blower
   / Some end of the year snow blowing video with my loader mounted hydraulic blower
I'd have to have a four inch square tube bumper protecting that reservoir tank or I'd back into something and hole it for sure. Very nice set up. What do they list for if we might ask?.
i thought about that, but i never back up without looking first. but who knows, might not be a bad idea.
The rear tank weighs about 450-500# full plus another 90# for the hydraulic motor, so its real nice rear ballast for the blower or the plow.
   / Some end of the year snow blowing video with my loader mounted hydraulic blower #12
I think those hydraulic QC blowers are the coolest things ever. Have you ever taken advantage of being able to lift your blower 8' in the air? I've love to attack a parking lot pile and just eat the thing. That cab is cheating, BTW.
I continue to run my 3pt blower with my open-cockpit tractor. It's just not fair....
JayC
JayC
yes, though not 8 feet. when i blow off the roof sloughed piles last year and this season, i lift it up 4-5 feet and take off the top section, then lower it to remove the rest. its amazing
and yes the cab is totally cheating....
and i love to cheat
   / Some end of the year snow blowing video with my loader mounted hydraulic blower #15
It's a great setup you have there, and you are in good company. All the big jobs now are done with loader mounted blowers.
Check out this clip from one of the most elevated roads in Sweden, at lat 65deg N. It's taken in mid-May when they start clearing the snow to be able to open the road on 6th of June. In October it closes again due to the snow.
Vildmarksvè‡*en sn??s i maj 2012! - YouTube
"The hardest part is staying on the road. When brush starts flying out you know you are off and just have to back up and try again to find the asphalt".
The blower is a norwegian Oeveraasen (Överåsen)
/Marcus
   / Some end of the year snow blowing video with my loader mounted hydraulic blower #16
grsthegreat, thanks for the video. Certainly works 100% better then when you first got it before you adjusted the blower.
   / Some end of the year snow blowing video with my loader mounted hydraulic blower #17
You would enjoy our weather today -- 10-12", wet heavy snow -- probably the most we've seen since the blizzard of '78. I was out for an hour before breakfast on my new Kioti: FEL and rear 3PH grader blade. This was my first experience with FEL in snow. If I had to choose, though, I'd keep the grader blade. It's really nice when the 3PH works well (my old tractor was very slow to raise when it was cold, didn't have stabilizer chains, etc...). I can back up and push, or angle and drive and clear a nice path down the county road.:)
It snowed so much on me, that my coveralls soaked clear through to the skin. Everything is inside drying out now. Will go out again and try to plow my daughter's drive out (about 1/2 mile away).
   / Some end of the year snow blowing video with my loader mounted hydraulic blower #18
Dave, you need one of these!
   / Some end of the year snow blowing video with my loader mounted hydraulic blower #19
I'm having a great time -- practicing in the backyard . :)
   / Some end of the year snow blowing video with my loader mounted hydraulic blower #20
I assume it has a relief type setup to limit damage it the blower jams, most i have seen around here have a bypass setup . Therefore no pins to shear.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
ACS 104" HYD PIN ON PIPE GRAPPLE (A52707)
ACS 104" HYD PIN...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A55851)
2016 Godwin CD150M...
White Metal Roof Panels (A55758)
White Metal Roof...
