Dirt Scraper (Dirt Pan) / Towed Vs. Dirt Scoop / 3-Pt. - WHICH ROUTE ????
   / Dirt Scraper (Dirt Pan) / Towed Vs. Dirt Scoop / 3-Pt. - WHICH ROUTE ???? #11
I need to move a hill about 250 yards to make a deep fill for a shop location I hope to build on before I die. :)
Got serious about a dirt pan. The size I looked at preferred 100 HP but my 60 HP was suggested MIN. After some looking I decided to stick with backhoe and 16' flat dump. It was all on my place but being able to back up and dump in tight places is a plus. Pans are not for use on paved roads in my view because of the mess they can make.
Moved a lot of dirt putting in a water way with just a 6' box blade about 200 yards to the other end of the field. It went much faster than I expected. Since you are making a glass smooth road in the process speed can be very high (for a tractor) going and coming when using a box blade. 50 years ago we moved gravel with a scoop but I think most would ditch that method FAST if there was much dirt move. :)
I have never used either, so I can't say what would be better, but according to the links you have above, the scoop only holds 10 cubic ft and the pan .9 yards (that is 24.3 cubic ft).
You are absolutely correct. I will modify opening post. See, I am learning.
AND THANK YOU.
   / Dirt Scraper (Dirt Pan) / Towed Vs. Dirt Scoop / 3-Pt. - WHICH ROUTE ???? #13
The specs for the DB4 also indicate a max HP of 35 and the 50 was the max HP for the 72" pan, but even at 24.3 cubic ft of dirt (should weigh somewhere around 2200 lbs plus the 1000lbs of scraper) it sounds to me like the pan is a self loading dump trailer and a box blade in one. $2000 would be a great price for what it can do if you ask me. Should be a lot faster than a dump trailer the size of the king kutter xb mentioned above if you are looking to reduce the grade in one area and raise it elsewhere. I would even think it would be just as fast to transport it as both would be pulled by a tractor, but if I were moving a lot of dirt more than 200 yards, I would want the biggest dump trailer my truck would pull and move 4 yards at a time a lot faster than the tractor would go.
   / Dirt Scraper (Dirt Pan) / Towed Vs. Dirt Scoop / 3-Pt. - WHICH ROUTE ???? #14
Just looked again at that pan (I want to dredge a pond - maybe around 4000 yards total to remove) and it is really making the gears turn - with the apron, it seems like it would be exactly like a dump trailer and could be loaded by a mini ex or backhoe. With that and my brothers 12k lbs dump trailer, the mini would stay much busier and I would have a nice tool to spread it all out nicely over a 3 acre field.
Here is a link to an old thread, but had some first hand experience and several other brands to look at. I didn't read it all yet and I started on page 6 if it, but it had a lot of cool info in the posts on that page:
http://www.tractorbynet.com/forums/attachments/50169-best-dirt-moving-attachment-found.html
I also found a used unit that went at auction for $2200 and a Craigslist add claiming a new one cost $3500, so they may be more expensive than the presumed $2000. Still very interesting to me.
   / Dirt Scraper (Dirt Pan) / Towed Vs. Dirt Scoop / 3-Pt. - WHICH ROUTE ???? #15
It sounds like you have a great start for what you need. You might also consider renting an excavator for a few days, and that may save you about half the cost of buying your own equipment if that is the only project that you will be working on with it. I use a Country Line by TSC dirt scoop every week, however I also do not have an FEL. The dirt scoop is great for most tasks, and will hold the same amount as a small FEL bucket, or about 9 Cubic Feet. They are also fairly easy to operate, because the design, and the physics allow the scoop to dump very easily when the level is released from your seat, even with the heaviest load. The weight is greatly depended on the type of soil, and the density, the moisture content. I have had scoops of dirt that weight close to 1k, and some that weight about 300lbs. It sounds like it may work for what you need it for however it will take longer with this implement, but it is a great tool, and especially useful for digging, and leveling, and I have been able to do almost everything that I thought I needed an FEL for, however I use ours mainly for moving soil for our vegetable plots, and moving, and leveling our ever growing endless supply of manure filled shavings from our animals. I hope that you are able to find what you need and have fun working on your project!
   / Dirt Scraper (Dirt Pan) / Towed Vs. Dirt Scoop / 3-Pt. - WHICH ROUTE ???? #16
I'm not sure what the DB-4 costs, but I imagine its not all that far off from the $5 grand that the DB-6 costs. It would certainly be a great tool to have and fun to use, but they sure are pricey too.
Consensus of advice: Hoelscher Scraper/Pan would be the most time efficient tool, IF my Kubota B3300 has enough power, 3-Pt. strength, weight and traction to overcome Hoelscher draft while scraping up dirt.
Big IF.
The King Kutter XB Trailer weighs 600 pounds and has a capacity of 35 cubic feet / 1-1/2 tons at somewhere around half of Hoelscher DB-4 price. Have to buy new from Northern Tool, which has KKXB as an exclusive, apparently. There is a Northern Tool store in Ocala, 70 miles away, so possibly can eliminate $455 freight by picking up there. KKXB comes as a kit, which I would assemble; no big deal but a day of my time. So far as I am aware, KKXB is the only KK branded product offered as a kit. Is KKXB kit manufactured in Alabama at the KK plant, or sourced in Asia with the KK brand? Is 'orange' a clue? Northern Tool is a big importer. Some imported kits are a bear.
If...If...Iffy.
XB_Dump_Trailer.wmv - YouTube
King Kutter Dump Trailer Review - Four Wheeler Magazine
The KKXB has been sold for several years but I cannot find even one customer review.
Any T-B-N readers have first hand experience with KKXB trailer?
I really do not want another trailer. I want to go a step beyond my existing Rollover Box Blade.
I have a King Kutter Rotary Mower and a King Kutter Rotary Harrow, both manufactured in Alabama and satisfactory attachments.
The 48" Hoelscher Dirt Pan weighs 980 pounds but has gauge wheels. Will not gauge wheels control/decrease draft?
Can someone with scraper experience answer this?
   / Dirt Scraper (Dirt Pan) / Towed Vs. Dirt Scoop / 3-Pt. - WHICH ROUTE ???? #19
Howdy Mitch, I'am guessing you have 30" scoop and not 24 .
Boone
   / Dirt Scraper (Dirt Pan) / Towed Vs. Dirt Scoop / 3-Pt. - WHICH ROUTE ???? #20
Possibly another suggestion; I had an old steel trailer, 4'x7' and 16" sides. I added to the sides to make it about 2-1/2' about. I put a pintle hitch on it so it matches one I have on my FEL. I can fill the trailer up with 5-6 loaded heaping scoops from a 60" FEL. I fill the trailer heaping until it rolls off the sides. I then hook it to my FEL and drive it the 100 to 200 yards and raise the front up to dump it. The trailer is fairly high because it has a mobile home axle, springs and tires. Once it starts to dump, because of the way I mounted my hitch I can stand the trailer on it's end to dump all the dirt. This is just an idea. It works great for me but will by no means work for everyone. I can move about 80 Cubic feet in one trip easily with almost no spill. This system I am just puttering around with the tractor most of the time in a 1/2 throttle position except when loading.
I have a 30" dirt scoop but found when I fill that and the FEL bucket and transport it over any bumps I lose some of it and it makes a mess on roads.
2025 KG45 UNUSED U-Type Screw Pin Shackle Set (A50860)
2025 KG45 UNUSED...
Yamaha Rhino 660 UTV (A50860)
Yamaha Rhino 660...
2015 Hooper T/A Trailer w/Mounted Foaming System (A50860)
2015 Hooper T/A...
2012 Buick Enclave Premium SUV (A50860)
2012 Buick Enclave...
2 Vintage Metal Signs (A48082)
2 Vintage Metal...
2017 Chevrolet Silverado 2500HD 4x4 Crew Cab Reading Service Truck (A48081)
2017 Chevrolet...
