What the heck is a #6 ORBF port?
   / What the heck is a #6 ORBF port? #1
Dongerosa
wellington ohio
7510 bota...RTV 900
Got some Shur lift hydraulic cylinders for my MID600 backhoe. the spec's state it has #6 ORBF ports. What are these? Need some help...
   / What the heck is a #6 ORBF port? #2
#6 ORBF
#6 = 6/16 = 3/8"
ORBF = O-ring boss, female
ISZ
   / What the heck is a #6 ORBF port? #3
Here's a 90 that'll screw into your cylinder (#6 means 6/16", or 3/8") and convert it to JIC connector, if that's what you have - this site has many others, just need to look around a bit to find an adapter to/from nearly anything hydraulic.
SAE 37° Flare (JIC) x O-Ring Boss (ORB) 90° Elbow
Also, more info on connections -
http://www.discounthydraulichose.com/v/vspfiles/downloadables/thread_guide.pdf
HTH... Steve
Thanks guys...so, SAE and ORB are the same things...great! btw, the guide is "Amazing" on how many styles exist...
   / What the heck is a #6 ORBF port? #5
No, SAE and ORB are NOT the same thing.
SAE = Society of Automotive Engineers (I didn't look it up, but they certainly standardized many different styles of fittings amoungst everything else they cover)
ISZ
   / What the heck is a #6 ORBF port? #6
ISZ is right - more correctly, SAE is a broad spectrum of standards - ORB is just ONE of those, but hydraulics places tend to use "shorthand" and refer to that particular standard as either SAE or ORB. Check the thread guide again, note that it calls ORB "SAE J1926-1" - And in the table of contents, this
SAE J514 37° Flare Hydraulic (JIC) . . . . . . . . . . . . . . . . . . . . . . . 6
SAE J512 45° Flare . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
SAE J1926-1 Straight Thread O-Ring Boss (ORB) . . . . . . . . . . . . . . 8
SAE J514 Flareless Tube Fitting . . . . . . . . . . . . . . . . . . . . . . . . . 9
SAE J1453 O-Ring Face Seal (ORFS) . . . . . . . . . . . . . . . . . . . . . . 10
SAE J512 Inverted Flare . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
In other words, a trout may be a fish but not all fish are trout... Steve
2017 TERRAMAC RT14 CRAWLER DUMPER (A60429)
2017 TERRAMAC RT14...
CAT CB34 (A60462)
CAT CB34 (A60462)
1996 Timpte 46ft Hopper (A56438)
1996 Timpte 46ft...
1998 MACK DUMP TRUCK (A60430)
1998 MACK DUMP...
JOHN DEERE 470G LC EXCAVATOR (A60429)
JOHN DEERE 470G LC...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
