What the heck is a #6 ORBF port?
   / What the heck is a #6 ORBF port? #1
Dongerosa
wellington ohio
7510 bota...RTV 900
Got some Shur lift hydraulic cylinders for my MID600 backhoe. the spec's state it has #6 ORBF ports. What are these? Need some help...
   / What the heck is a #6 ORBF port? #2
#6 ORBF
#6 = 6/16 = 3/8"
ORBF = O-ring boss, female
ISZ
   / What the heck is a #6 ORBF port? #3
Here's a 90 that'll screw into your cylinder (#6 means 6/16", or 3/8") and convert it to JIC connector, if that's what you have - this site has many others, just need to look around a bit to find an adapter to/from nearly anything hydraulic.
SAE 37° Flare (JIC) x O-Ring Boss (ORB) 90° Elbow
Also, more info on connections -
http://www.discounthydraulichose.com/v/vspfiles/downloadables/thread_guide.pdf
HTH... Steve
Thanks guys...so, SAE and ORB are the same things...great! btw, the guide is "Amazing" on how many styles exist...
   / What the heck is a #6 ORBF port? #5
No, SAE and ORB are NOT the same thing.
SAE = Society of Automotive Engineers (I didn't look it up, but they certainly standardized many different styles of fittings amoungst everything else they cover)
ISZ
   / What the heck is a #6 ORBF port? #6
ISZ is right - more correctly, SAE is a broad spectrum of standards - ORB is just ONE of those, but hydraulics places tend to use "shorthand" and refer to that particular standard as either SAE or ORB. Check the thread guide again, note that it calls ORB "SAE J1926-1" - And in the table of contents, this
SAE J514 37° Flare Hydraulic (JIC) . . . . . . . . . . . . . . . . . . . . . . . 6
SAE J512 45° Flare . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
SAE J1926-1 Straight Thread O-Ring Boss (ORB) . . . . . . . . . . . . . . 8
SAE J514 Flareless Tube Fitting . . . . . . . . . . . . . . . . . . . . . . . . . 9
SAE J1453 O-Ring Face Seal (ORFS) . . . . . . . . . . . . . . . . . . . . . . 10
SAE J512 Inverted Flare . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
In other words, a trout may be a fish but not all fish are trout... Steve
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
John Deere 6195R (A60462)
John Deere 6195R...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
Toro z turn (A56859)
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
