C-123 Engine
   / C-123 Engine #12
That's interesting about the C-135 cam Rick. I went to Case/IH to compare the part numbers, but they have been down for maintenance for a few days, and STILL down...
Where did you find the lift/duration specs on the cams..?? Are they in the Blue Ribbon engine spec manual..?? I have a BR engine manual that covers several engines, but it's at the other farm.
I'm guessing just a longer duration..?? I just happen to have a C-135 cam and gear, and a spare C-123 waiting on an engine stand to be OH'd for an A, as a play toy for plowing days.
I'm wondering how much power increase you would get NOT shaving the head. I already have a NIB overbore kit just waiting to be installed. Too many irons in the fire now, for play things. But it would be sweet to build a little "sleeper", when the time comes...
   / C-123 Engine #13
After doing some checking of part numbers yesterday, after finally being able to access Case/IH parts, I was quite surprised to see that the same cam was used in the C-123, up through the C-153 4 cyl. engines. And same 66tooth cam gear... Even the C-113 cams were replaced with the 353609R31 cam if a new one is needed. Could be the same lift, and duration, just a different part number..??
So I guess I'm asking Rick, why the C-135 cam..?? Unless you had it reground..??
   / C-123 Engine #14
I was told by an old-time IH mechanic that the 135 cam had better performance characteristics. So I bought one.
   / C-123 Engine
Oh yeah...sorry. I flat glossed over that. So you got a 50% PTO HP increase simply by shaving the head and putting a different cam in. That is truly amazing. I would have thunk maybe 30% max! Thanks for the tip. I'm gonna have to get me another engine and tweak it.
   / C-123 Engine #16
That's not all I did to it. In fact, that's not even all that I've already told you that I did to it. You get to figure the rest out on your own.
   / C-123 Engine #17
Well..., reckon' I'll just have to settle for the 3-1/4" overbore kit, and some cleaning up of the manifold ports.
   / C-123 Engine #18
Rick...If you hang around C's, SC's, 200s, 230s, etc. long enough you will ultimately find out what the weak link in these units are...once you hit a certain horsepower/torque level you very well may find out the hard way....Oh yeah, "You get to figure the rest out on your own."....If you'd like to know you may ask politely....Not a sermon, just a thought. BobG in VA
   / C-123 Engine #19
rick plainly stated what he did and what he got and the other poster missed it twice!
I don't feel bad one bit telling a person to go re-read what I've already typed.. and that's not a sermon..
   / C-123 Engine #20
I don't care what Rick did, I said that once you reach a certain level of torque/HP on these units you are in for other issues....That's all I'll say...and you can call it a sermon if you like..
DEUTZ MARATHON...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
378721 (A54865)
378721 (A54865)
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
