At Home In The Woods
   / At Home In The Woods #4,591
Obed, your solution is obvious. You should start hinting now for a man-lift under the Christmas tree. Just think of all the tree trimmin' and other high jobs around the house. No more worry about the gutter cleaning. Just a nice ride on the man-lift and it's done.;)
I would wager on the likelyhood of my winning the lottery may be better....
   / At Home In The Woods #4,592
I would like opinions on the so called "creosote logs" that are supposed to clean your flue by just burning one every so often where the build up flakes off and falls down to the fire pit. Do they work and worth buying?
I cal Horse Apples on those things. A brush is the only way to effectively clear creosote.
Obed, yes it is supposed to work from the basement up. I put in a "T" above the stove just for clean out purposes:
   / At Home In The Woods #4,593
Now see, that's my problem--I just don't think big enough. :laughing:
   / At Home In The Woods #4,594
you need to get all that wood split and not split a bit at the time.
Yes a "real" saw is worth its weight! I am cheap but a good stihl saw is worth it!!
I hope your brush is poly a steel brush is not good for SS.
   / At Home In The Woods #4,595
Obed, I don't burn wood for heat, but your photos scared the livin' poo out of me.:shocked: You've burned only one season and your chimney was an accident waiting to happen. I think you are lucky to have had some smoke back up into your house. I ran out and looked at my fireplace vent after seeing your pictures. I burn oak exclusively and most of it a very hot fire, but my chimney tiles are 13" x 18" and must take awhile to get really hot. All I ever see is thin black soot coating. Do you think you may have clogged that chimney due to your original problems with your insert? I'm thinking of an insert so I can get some benefit from all the available firewood on my place. Those photos of yours sure will make me take the installation seriously. I'm going to put an insulted stainless duct up my flue even if it is only 10 years old. Thanks for posting that sobering evidence that installation, dry wood, and burning technique are so important.
Go over to hearth.com and read the forums there. You will learn a lot and learn how to do an install yourself. I put an insert in 3 yrs ago and will never burn in a fireplace again!!
   / At Home In The Woods #4,596
Rick,
Let us know how well that thing works. Do you plan on using it from inside the house?
Obed
guys over at the hearth love those things who have them. The problem they say is that their kind of dusty and dirty as you cant have the stove door closed or you cant put a bag over the bottom of your pipe like you could if you have a free stander tape a bag to it and clean from the roof.
I'm going chainsaw shopping. I'll probably buy a Stihl.
   / At Home In The Woods #4,598
Obed. Stihl or husqvarna is all I see the loggers in our area carry. I have 3 saws. A 32 which us way too big, an old 20 that isn't very safe and a small 14. I would consider a 30 cc unit with a 24 in bar to probably being the most ideal residential saw.
   / At Home In The Woods #4,599
24" bar on 30cc seems like low power? My Husky 455 has a 55.5cc and 20" bar. In hard woods, that seems about right.
   / At Home In The Woods #4,600
no way a 30cc saw will turn a 24 inch bar in wood!! I don't know if you could find a 24" bar for a 30cc saw?
I agree with you, a 60cc is about marginal size to run a 24" bar. I think my ms390 stihl is something like 63cc give or take?? I have a 20" bar on it and it can run totally sunk in oak but I think a 24" bar, which I want, will be about to big to run full chain on, If I do get a 24" bar I will run skip chain on it.
Obed when you run a stihl for the first time and start it with 3 pulls regardless of it sitting for 2 weeks or 2 months you will be happy. I have replace a fuel line in mine and the decomp valve is all that I have done on mine in 8 yrs, I waited to long on the decomp valve and it actually fell apart and got jammed in the cylinder and I had to disassemble the saw to remove it, but one I put it back togeather it ran fine afterward.
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
2011 Toyota Corolla (A55758)
2011 Toyota...
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
HEAVY DUTY 7' X 13' X 3.5' WAREHOUSE STORAGE SHELF (A54757)
HEAVY DUTY 7' X...
Hercules Gun Safe (A55758)
Hercules Gun Safe...
2003 John Deere 2500A (A54865)
2003 John Deere...
