Cleaning Transmissiion Suction Screen when changing Oil
   / Cleaning Transmissiion Suction Screen when changing Oil #1
MMH
Gold Member
Murrysville, PA
JD 4500
Manual indicates that suction screen should be cleaned w/ a mild solvent. I have carburetor cleaner (gallon can w/ bucket in it). Can I clean the screen in this or would it be too aggressive?
   / Cleaning Transmissiion Suction Screen when changing Oil #2
I just use some gasoline / kerosene. Easier on skin & lungs!~!! Used paint brush to get the steel filings out of screen.
Good luck!!!
   / Cleaning Transmissiion Suction Screen when changing Oil #3
You don't really need an aggressive solvent for the job. Just something to clean the hyd fluid from the metal filing's to get them loose from the mesh screen. I used some lo-volatil part's cleaner and parts brush for most of the cleaning but an old toothbrush for the last of the really fine metallic stuff.
AKfish
   / Cleaning Transmissiion Suction Screen when changing Oil #4
AKfish
I like to use starting fluid... the buzz is better:thumbsup:
   / Cleaning Transmissiion Suction Screen when changing Oil #5
   / Cleaning Transmissiion Suction Screen when changing Oil #6
i use air pressure to clean mine.
   / Cleaning Transmissiion Suction Screen when changing Oil #7
That was the final step before re-installing. My compressor is set for 175psi. So, I was pretty careful not to damage the screen and/or the screen seam at each end of the tube.
AKfish
Ended up using kerosine & a gun cleaning nylon brush. Blew out w/ air compressor to dry. Expected to find sludge on the screen, but jiust some minor metal chips, so kerosene worked good.
2015 Ford F450 Flatbed Truck (A52377)
2015 Ford F450...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55302)
2023 New Holland...
2016 Freightliner M2 106 Cab and Chassis Truck (A52377)
2016 Freightliner...
Toro Mower (A50324)
Toro Mower (A50324)
2015 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2015 Chevrolet...
