Cleaning Transmissiion Suction Screen when changing Oil
   / Cleaning Transmissiion Suction Screen when changing Oil #1
MMH
Gold Member
Murrysville, PA
JD 4500
Manual indicates that suction screen should be cleaned w/ a mild solvent. I have carburetor cleaner (gallon can w/ bucket in it). Can I clean the screen in this or would it be too aggressive?
   / Cleaning Transmissiion Suction Screen when changing Oil #2
I just use some gasoline / kerosene. Easier on skin & lungs!~!! Used paint brush to get the steel filings out of screen.
Good luck!!!
   / Cleaning Transmissiion Suction Screen when changing Oil #3
You don't really need an aggressive solvent for the job. Just something to clean the hyd fluid from the metal filing's to get them loose from the mesh screen. I used some lo-volatil part's cleaner and parts brush for most of the cleaning but an old toothbrush for the last of the really fine metallic stuff.
AKfish
   / Cleaning Transmissiion Suction Screen when changing Oil #4
AKfish
I like to use starting fluid... the buzz is better:thumbsup:
   / Cleaning Transmissiion Suction Screen when changing Oil #5
   / Cleaning Transmissiion Suction Screen when changing Oil #6
i use air pressure to clean mine.
   / Cleaning Transmissiion Suction Screen when changing Oil #7
That was the final step before re-installing. My compressor is set for 175psi. So, I was pretty careful not to damage the screen and/or the screen seam at each end of the tube.
AKfish
Ended up using kerosine & a gun cleaning nylon brush. Blew out w/ air compressor to dry. Expected to find sludge on the screen, but jiust some minor metal chips, so kerosene worked good.
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
2016 Dodge Charger SRT Hellcat Sedan (A53424)
2016 Dodge Charger...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2017 Caterpillar D5 K2 LGP (A55218)
2017 Caterpillar...
2021 New Holland C327 Compact Track Loader (A55218)
2021 New Holland...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
