New Home Begins
   / New Home Begins #301
DING DING DING
sdkubota and KennyG back to your prospective corners! This will be the last and final round. Debaters, protect your opinions at all times. Extra points will be given for verifiable references. Opinions only will be counted against you. Come out fact slinging at the sound of the bell.
DING
Debate!
:) Aw, just joshing. I am truly interested! I have a ballast box full of curing concrete in my (currently) unheated work shop - temps stay around 40 when I don't have a fire going. Poured it last Friday.
This little side jaunt has been informative :)
Looks nice...I lined my forms with plastic sheeting and the concrete was real smooth although a corner got a little messed up. What does that weigh? Here is the one I made that weighs in at 1,000 lbs:
   / New Home Begins #302
As I recall, the Hoover Dam has cooling pipes in it that were placed for the sole purpose of controlling curing temperature due to the project location's climate and the amount of heat generated by so much concrete curing at one time.
Exactly correct...the massive pours created so much heat it had to be removed or it would have damaged the concrete. The also had a huge ice machine to use ice in the mix instead of water to help keep the concrete temps within acceptable ranges.
   / New Home Begins #303
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=297972"/>
Mine weighs between 2400-2500 pounds. Don't want to hijack, I plan on starting a thread soon.
   / New Home Begins
Well, a stalled weather front on the east coast has dumped rain over a three day period. Luckily mostly at night, so the framers were able to work except for yesterday. With any luck, by the end of Saturday or Monday at the latest, all of the walls will be complete. Next week ... trusses if they can be delivered on time or the great room timbers (rafters, ridge and collar ties) if not. They would prefer to do the trusses so they have someplace to walk to facilitate the timbers.
P1020638.jpg P1020639.jpg P1020640.jpg P1020641.jpg P1020642.jpg P1020643.jpg P1020644.jpg P1020645.jpg P1020646.jpg
P1020647.jpg P1020650.jpg P1020651.jpg P1020652.jpg P1020653.jpg P1020654.jpg
   / New Home Begins #305
Tom, a few questions for you if you don't mind. The neighbor who you had a few words with is he on the chain link fence side or the side with the split rail fence? Why I ask is it looks like some of the excess water is running into the yard with the split rail fence and didn't know if that neighbor had anything to say about it. It wouldn't bother me but I know you had a finicky neighbor!
Also just curious why the framers didn't skin the walls on the garage first before lifting them into place? No place to lay the wall down to build it without it being in the mud? And thanks for the photos, enjoying your build. Stanley
   / New Home Begins
Stanley,
The neighbor with the issue is on the split rail side. The water over the past three days is the highest it has been and it is still below the cut of the top soil removal. There is one naturally low spot near the fence but it really did not encroach beyond the fence. Besides, his fence is 5' into our property anyway, so the water near the line is really on our property anyway. That issue and how to resolve is still being investigated with the title company.
As for the framer's not skinning the garage walls, I am not sure. It may have been more hassle since each wall was put up in sections and to stagger the seams would have meant that only 1-2 pieces per wall section would have gone up. This is speculation on my part but I will ask.
The garage is lowered as you can see and they did make the garage walls up on the main floor decking then lower them into place with the telehandler.
   / New Home Begins #307
Tom:
You are making phenomenal progress with your project, and I thank you for sharing it with the group. :thumbsup:
Note to Muhammad (sp); Please...please...please put a modern pop-up photo viewer on TBN! Thanks!
   / New Home Begins
Tom:
Now that you mention it, a photo viewer that can let you scroll through all the photos without having to go back to the main thread.
   / New Home Begins #309
Stanley, The water over the past three days is the highest it has been and it is still below the cut of the top soil removal. There is one naturally low spot near the fence but it really did not encroach beyond the fence.
/QUOTE]
I'm surprised the local inspector didn't make you put up a silt fence. The inspectors here in Harford County Maryland are referred to as the "dirt police" because you can't move a shovel full of dirt without the fence.
   / New Home Begins
We did have to contact the soil conservation unit of the county. We were under the threshold amount of disturbed soil so did not have to put one up.
:D
(7) John Deere Weights (A50121)
(7) John Deere...
(11) 2 PLUG VALVES (A52472)
(11) 2 PLUG VALVES...
2016 Mercedes-Benz GL450 4MATIC AWD SUV (A50324)
2016 Mercedes-Benz...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
Swict 7' Fork Extensions (A50121)
Swict 7' Fork...
