6420/640JD loader joystick won't operate
   / 6420/640JD loader joystick won't operate #1
Carmen
Dunseith, ND
6420 JD/640 JD loader
The tractor & loader has only 800 hrs. And the joystick will not operate I'm stumped please help
   / 6420/640JD loader joystick won't operate #2
If it "will not operate" as in "joystick will not move" you have moisture frozen in the cables or some other problem with the cables.
   / 6420/640JD loader joystick won't operate #3
Simple question... Is the lock lever in the operate position? It's located low on column that holds the joystick.
It's easy to bump to lock ...
I thought about that but gave the guy a little credit. :)
This joystick is ,electronic not manual. The stick is in the console.
   / 6420/640JD loader joystick won't operate #6
I see. Sounds like you need to check fuses and possibly call a dealer.
   / 6420/640JD loader joystick won't operate #7
2011 Ford F-350 Knapheide Stakebed Truck (A52377)
2011 Ford F-350...
CAT CHALLENGER 65B (A53843)
CAT CHALLENGER 65B...
2003 Evan's Log Trailer, Super Singles (A52384)
2003 Evan's Log...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
Unused 2025 GIYI KH72 72in 4-Way Hydraulic Bucket Skid Steer Attachment (A51691)
Unused 2025 GIYI...
