6420/640JD loader joystick won't operate
   / 6420/640JD loader joystick won't operate #1
Carmen
Dunseith, ND
6420 JD/640 JD loader
The tractor & loader has only 800 hrs. And the joystick will not operate I'm stumped please help
   / 6420/640JD loader joystick won't operate #2
If it "will not operate" as in "joystick will not move" you have moisture frozen in the cables or some other problem with the cables.
   / 6420/640JD loader joystick won't operate #3
Simple question... Is the lock lever in the operate position? It's located low on column that holds the joystick.
It's easy to bump to lock ...
I thought about that but gave the guy a little credit. :)
This joystick is ,electronic not manual. The stick is in the console.
   / 6420/640JD loader joystick won't operate #6
I see. Sounds like you need to check fuses and possibly call a dealer.
   / 6420/640JD loader joystick won't operate #7
2012 TRAVIS 39FT DUMP TRAILER (A53426)
2012 TRAVIS 39FT...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
1267 (A50490)
1267 (A50490)
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
Kawasaki NR (A50324)
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
