6420/640JD loader joystick won't operate
   / 6420/640JD loader joystick won't operate #1
Carmen
Dunseith, ND
6420 JD/640 JD loader
The tractor & loader has only 800 hrs. And the joystick will not operate I'm stumped please help
   / 6420/640JD loader joystick won't operate #2
If it "will not operate" as in "joystick will not move" you have moisture frozen in the cables or some other problem with the cables.
   / 6420/640JD loader joystick won't operate #3
Simple question... Is the lock lever in the operate position? It's located low on column that holds the joystick.
It's easy to bump to lock ...
I thought about that but gave the guy a little credit. :)
This joystick is ,electronic not manual. The stick is in the console.
   / 6420/640JD loader joystick won't operate #6
I see. Sounds like you need to check fuses and possibly call a dealer.
   / 6420/640JD loader joystick won't operate #7
Adams 5T HC Spreader (A53473)
Adams 5T HC...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A53473)
GOODYEAR SET OF...
2005 Ford E-450 Super Duty Ambulance (A51692)
2005 Ford E-450...
