MF 165 knocking
   / MF 165 knocking
This thread can be moved to the new Classic section.
I have had this project on hold, but should get back on it soon.
   / MF 165 knocking #32
You can probably use the report button (bottom left triangle) and state where to move it in the message thread.
   / MF 165 knocking
This project is back on my to do list. Bought a standard crank and have it sent off for polishing or turning if needed. Also have a master overhaul kit, oil pump and other goodies coming from the local MF dealer. If anyone is interested I will post progress pics.
   / MF 165 knocking #35
We love pit'chers..!!
   / MF 165 knocking
Tear down continues
The filter caught some of the spun rod bearing pieces
This is a good reference pic for where the different length studs go
Removing head studs
While maybe not the ideal method it works (thanks for the tip shona13). I did find minor damage from sometime in the last forty years of someone else doing this same job
Somebody made a mess
Degreasing time
Got some goodies
Primed and block painted, finally time to turn the corner and start assembly
The Crankshaft I bought should be ready soon from the machine shop, for now I'll continue to clean and prep parts
   / MF 165 knocking #37
I just love simple green.
   / MF 165 knocking #38
G'day Da Butcher.
Good to hear from you again.
I,d say your approach to the job is spot on,everything nice and clean,excellent pictures and I am sure the members would like to see MORE, Please.
Keep up the good work.
Regards.
Hutch.
   / MF 165 knocking
Ran into my first problem. The sleeves that came out have a thick flange that goes into the counter bore of the block and the new ones are thin flange. Called the parts guy and his conclusion is I have a early block with a later direct injection head. He is going to order the indirect rebuild kid and swap it out for me. I thought from early on something wasn't adding up about the engine because this appears to be a 1972 model tractor and by then the engine should not have the rope rear main seal yet it does. Question: Does this combination of head a block work good or create monsters? Previous owner ran it for a few years like this, but did have #1 piston and sleeve replaced.
I'll get a better pic later
   / MF 165 knocking
Ditto........I did use several products including Gunk degreaser followed by the Simple Green the lots of pressure washing
2004 JOHN DEERE 5320 TRACTOR (A51243)
2004 JOHN DEERE...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2012 VANGUARD 53FT DRY VAN TRAILER (A52141)
2012 VANGUARD 53FT...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
