Dump trailer, Finally decided what I am buying.
   / Dump trailer, Finally decided what I am buying. #11
Those are nice looking trailers. It sounds like you got a good deal on it. One thing I don't like that all dump trailer manufacturers do but is easily fixable is put the battery in the toolbox without a vent kit. Looks like to me over a period of time that would rust the box and everything inside it.
There is a hole to vent the box in the back about 2".
I have some spray in bed liner and may line the inside of the battery box.
It's a beauty. I have been lucky to borrow one. I like the size of your. Must have a large truck to handle this.
I have a 1998 Chevy 1 ton dooley with a 454 / 7.4L.
   / Dump trailer, Finally decided what I am buying. #13
Agree. Fix it by using a marine style plastic box to place the battery in and your done.
That would be an easy solution!
Thanks
   / Dump trailer, Finally decided what I am buying. #15
Is your trailer wired so, it will charge the dump battery from the truck when plugged in ? Mine wasn't but is now
   / Dump trailer, Finally decided what I am buying. #16
You have any details on how to wire this?
   / Dump trailer, Finally decided what I am buying. #17
I have always wanted a dump trailer, and it would have to be long enough to haul my tractor and have ramps also. The only problem I have is the trailer would have to have a 12 to 14K GVRW, and here in PA if you go over 10K you are legally required to have a combination registration which from what I have heard is a real PITA! So consequently I just have never bought one. There really isn't any reason to buy something that you can't use, although I do tow a 12K equipment trailer to haul my tractor now the truck is only a 3/4 ton 4x4 quad cab but it doesn't even know its back there. Rules and regulations are there for a reason but sometimes they are just stupid!
   / Dump trailer, Finally decided what I am buying. #18
If you have a 7 pin plug .On the truck there will be 1 spade that is always hot ( it is on mine) Run a wire from the trailer batt to the same spade on the trailer plug.I installed a diode at the trailer batt. to keep from back feeding current .keeping 12v from being at the trailer plug when disconnected from the truck
   / Dump trailer, Finally decided what I am buying. #19
What does one these babies cost roughly?
I bought mine from a rental company.It was time for them to sell it. Mine is somewhat like his.Mine is 16 ft long and has 2- 7K axles ,ramps in rear.I offered and bought it for 3 K I see he has 2 hyd. cylinders .(1 each side) where mine has only 1 large 1 in the center
   / Dump trailer, Finally decided what I am buying. #20
Nice trailer , great price . It looks like they accidentally got some paint on the underside . I bought a new GN about 5 years ago , Diamond C . After looking at their site and reading all the bull about the paintjob they did I thought okay . Went to pick it up , crawled under it , crawled out , told dealer the deposit check was no good and waved good by .It looks yoy have a nice trailer .
2003 Lincoln LS (A50324)
2003 Lincoln LS...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
