15' copper rod. Worth anything?
   / 15' copper rod. Worth anything? #1
clovergamecock
Gold Member
Clover SC
Kubota L2800 4WD FEL
I was crawling under an old house we are moving and found a solid copper rod. Is it worth anything?? I know people use to steal copper around here left and right. they finally tightened up the laws on scrapping copper to reduce theft.
   / 15' copper rod. Worth anything? #2
Scrap bare, bright copper is going for about three dollars a pound.
   / 15' copper rod. Worth anything? #3
Are you sure it is not just a copper plated steel electrical ground rod?.. What was the rod used for.? Is it about 5/8 inches in diameter. I am thinking you have found a ground rod, and it costs about $12 new, and no particular value, scrap except as a ground rod:) What would a copper rod be doing under a house?.. A steel/copper plated ground rod, yep,..I can see that.. Occam's razor.. think horses not zebras.
James K0UA
   / 15' copper rod. Worth anything? #4
Well I just re read your post and see it is 15 feet.. not so likely a ground rod then... Did you cut it to see if it is for sure solid copper.?
   / 15' copper rod. Worth anything? #5
Copper won't attract to a magnet,but copper-coated steel will stick a magnet. Check it out or just cut thru it like was suggested.
As far as its worth......something like that new would cost a pretty penny as the sayin' goes. don-ohio
   / 15' copper rod. Worth anything? #6
I was thinking the same thing, but as you said, the length would make it an unusually long ground rod.
   / 15' copper rod. Worth anything? #7
its a ground rod, if solid copper is close to $3/lb.
   / 15' copper rod. Worth anything? #8
It's worth it's weight in... copper. Assuming it's made of solid copper.
   / 15' copper rod. Worth anything? #9
Just picked up 15 , 8' copper plated/clad steel ground rods brand new from gentleman that had them stored in his barn for years . Traded him a trailer jack for it. Worked out good for both of us. Plan on useing them for ground rods on my livestock electric fence.
Boone
STEEL SLINGS (A54757)
2008 Sterling Bullet Utility Truck, VIN # 3F6WK76A88G352277 (A54865)
2008 Sterling...
2001 Ford F150 (A50121)
2001 Ford F150...
2011 Toyota Corolla (A55758)
2011 Toyota...
2016 Case 821F Articulated Wheel Loader (A55851)
2016 Case 821F...
UNUSED EINGP SCL850 STAND ON SKID STEER (A54756)
UNUSED EINGP...
