15' copper rod. Worth anything?
   / 15' copper rod. Worth anything? #1
clovergamecock
Clover SC
Kubota L2800 4WD FEL
I was crawling under an old house we are moving and found a solid copper rod. Is it worth anything?? I know people use to steal copper around here left and right. they finally tightened up the laws on scrapping copper to reduce theft.
   / 15' copper rod. Worth anything? #2
Scrap bare, bright copper is going for about three dollars a pound.
   / 15' copper rod. Worth anything? #3
Are you sure it is not just a copper plated steel electrical ground rod?.. What was the rod used for.? Is it about 5/8 inches in diameter. I am thinking you have found a ground rod, and it costs about $12 new, and no particular value, scrap except as a ground rod:) What would a copper rod be doing under a house?.. A steel/copper plated ground rod, yep,..I can see that.. Occam's razor.. think horses not zebras.
James K0UA
   / 15' copper rod. Worth anything? #4
Well I just re read your post and see it is 15 feet.. not so likely a ground rod then... Did you cut it to see if it is for sure solid copper.?
   / 15' copper rod. Worth anything? #5
Copper won't attract to a magnet,but copper-coated steel will stick a magnet. Check it out or just cut thru it like was suggested.
As far as its worth......something like that new would cost a pretty penny as the sayin' goes. don-ohio
   / 15' copper rod. Worth anything? #6
I was thinking the same thing, but as you said, the length would make it an unusually long ground rod.
   / 15' copper rod. Worth anything? #7
its a ground rod, if solid copper is close to $3/lb.
   / 15' copper rod. Worth anything? #8
It's worth it's weight in... copper. Assuming it's made of solid copper.
   / 15' copper rod. Worth anything? #9
Just picked up 15 , 8' copper plated/clad steel ground rods brand new from gentleman that had them stored in his barn for years . Traded him a trailer jack for it. Worked out good for both of us. Plan on useing them for ground rods on my livestock electric fence.
Boone
ROADTEC RP-190E-3043 ASPHALT PAVER (A52705)
ROADTEC...
New Wolverine 44" Mini Skidloader Flat Bottom Grapple (A50775)
New Wolverine 44"...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
2020 Kinze 3505 High Speed 6/11 Planter (A55302)
2020 Kinze 3505...
