A3.135 piston question
   / A3.135 piston question #1
curt3969
Massey 35
Hello, I tried to search this with no luck. I hope someone can answer this for me. As I was installing my new rings on the pistons. It is a 5 ring piston by the way, I noticed that the 4th ring from the top (oil ring) is different from the ones on the old pistons. The new one is not a solid cast ring but a squigily one with a thin ring on top and bottom of it. Kinda what you would see on a small block chevy. But the kit was listed 5th 4th 3rd and so on. All the other rings are the same except the 4th ring. Has anyone seen this before?
   / A3.135 piston question #2
Is this your piston? - kid
   / A3.135 piston question #3
That's a oil control ring.
I have flat top pistons. But the ring positions are the same. I have the vertical injectors.
Sorry its is a A3.152 perkins. 1962 massey 35. Thanks for the input.
   / A3.135 piston question #6
Curt, I'll scan that page and sent it to you in a private message in few minutes. -robert
   / A3.135 piston question #7
Right, the direct injection AD3. engines had the dished piston top.
Unfortunately I am just now finding out more about one of my AD3.152's pistons than I ever expected to know. It drew at least part of #1 liner into the crankcase. Made kind of a mess. Part of the liner ended up being crunched (pulverized) at the head.
Thanks, The Manual I have says its a spring loaded laminated scraper ring. Thats fine, but I need to find out if this "new ring" can be used to replace the original. This whole rebuild is due to piston failure after a rebuild. I will try to post a pic of the old and new tomorrow and see what you all think. I bought this project due to excessive oil consumption. Turns out the lands between the rings were all busted up. I just want to be sure that this scraper ring is correct.
2016 INTERNATIONAL MA025 BOX TRUCK (A53426)
2016 INTERNATIONAL...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2014 GMC Sierra 1500 Crew Cab Pickup Truck (A51692)
2014 GMC Sierra...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
(4) 64" X 40" ALUMINUM POP-UP SIDE WINDOWS (A51248)
(4) 64" X 40"...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
