Pallet Fork Question
   / Pallet Fork Question #12
Pass, you well not like them when you use them.
   / Pallet Fork Question #14
What will I not like about it?
I think those free floating type of forks will always want to maintain "level" no matter how much you place them in the "dump" position. Not good if you need to tip your forks to get into anything or tip them to let something slide off. I have and prefer fixed.
   / Pallet Fork Question #16
Thanks Todd.
You're welcome. I had an old set of Wifo (made in Canada) forks of that type. A) They were very heavy. B) They were of the type that you pictured. They behaved as I described above. I really didn't care for them. Sold 'em and went with the fixed type.
   / Pallet Fork Question #17
Exactly!
   / Pallet Fork Question #18
I also have rotating bar forks which I made myself. They have lifted everything I have asked that the fel allows. Stuff can slide off of them because the weight of the stuff keeps them pinned to the back bar until it slides off. You can pick up stuff as the weight of the forks also allow a slight tipping enough to get under. Mine cost $150 to make.
   / Pallet Fork Question #19
I'll try again
   / Pallet Fork Question #20
Hi
I'm looking for a pallet fork for my 870 JD that has a 300X loader and will use this for light work around the house mainly while doing some landscaping this year. Can't imange I would be lifting anything heaver than 1000 lbs.
I ran across this pallet fork localy and the seller is asking $400, cheapest I have found is about $650 new.
What do you think about this?
Hi Dennis and All,
The closest thing to those forks selling for $400 are probably the HLA light duty ones. Maybe those are an older design of theirs. Personally, I wouldn't pay more than about $225-250 for those, especially given their outdoor condition. You would want to flip them over and look at the amount of rusting underneath/bottom. If they are homemade, all bets are off. You should be able to tell by how the pieces are cut or maybe the weld quality.
With your 300 loader, I would recommend you get something more substantial for your own safety. You might think you will only move light things, but inevitably you will rationalize this over time. Plus, your tractor doesn't know you only want to move light things. One accidental jerk of the joystick with a marginal load and you could twist them up like a pretzel, hopefully not hurting yourself in the process.
Regarding fixed vs floating forks, there is a some information about their differences here: Pallet Fork Design Comparison.
Good luck in your quest!
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2011 Liebherr L586 (A52128)
2011 Liebherr L586...
2020 Hitachi ZX60USB-5N (A47384)
2020 Hitachi...
2009 FREIGHTLINER CASCADIA SLEEPER (A51222)
2009 FREIGHTLINER...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
