Pallet Fork Question
   / Pallet Fork Question #21
Regarding fixed vs floating forks, there is a some information about their differences here: Pallet Fork Design Comparison.
Nice link, Artillian. A better explanation than my sorta lame verbal one. As the link says, if you're moving pallets on level surfaces all day long, the floaters may be OK for you. But fixed are much better for all purpose use.
   / Pallet Fork Question #22
Thanks Todd, and I was only hoping to add to your excellent verbal explanation.
   / Pallet Fork Question #23
I too, am in the market for a set of pallet forks. I'm hopping to be able to fasten them together, or remove one and dig out some 4' diameter trees that I want to transplant. Has anyone who has a good quality set of pallet forks ever used them for a similar purpose? How did it work out?
   / Pallet Fork Question #24
Check out Artillian's link in the above post. It explains how the forks work on most fixed models. The forks can be slid toward the center of the rack to be put nearer to each other. Generally, if you slide the fork to dead center, you can pull out on the bottom while lifting up on the fork to remove it if needed. But be advised, each fork tine is usually pretty heavy.
When I need to remove my forks from the rack to add a trailer hitch receiver, I lower the forks to about 6 or 7 inches from the floor and then slide a cheap Harbor Freight moving dolly under them. They remain standing on the dolly and it saves your back from lowering them completely to the floor. Plus, you can roll them out of the way.
   / Pallet Fork Question #25
Good point about the forks coming out when slid to dead center. I let a set of the type that slides on a bar, get away from me yesterday. The advertiser needs ro remove his ad from Craig's List. I'm thinking I could build a frame for a pair like that, slide them to the center, then attach a bracket to prevent float and hold them together. Artillian's link makes me think that the hybrid type probably wouldn't suit my intended purpose.
   / Pallet Fork Question #26
Ill have to look at my set, but I don't think they are removable. They are heavy though. When I adjust them I raise the loader up and point the forks straight down at the ground so all the weight is off the slide. They move in and out much easier that way.
   / Pallet Fork Question #27
They went on, They will come off. How else do you replace worn out forks?
   / Pallet Fork Question #28
Good point but I know I have put them together in the center for digging. Not sure how they come off. Ill look at them and take a pic tonight. They are frontier. Not sure of model #
   / Pallet Fork Question #29
been lookin for a set of forks pin style mount for a long time,I just didn't want spend a grand on them.........
   / Pallet Fork Question #30
There's a notch dead center for one fork. Never looked for it or really paid it much attention. Hope I won't need it anytime soon. This set is way stouter than I need but it was a deal I had to take.
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2007 Ford F350 Super Duty (A50514)
2007 Ford F350...
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
2016 FREIGHTLINER 2500 SPRINTER VAN (A51222)
2016 FREIGHTLINER...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
Irrigation Pump (A52128)
Irrigation Pump...
