Convert walk behind snow-thrower into a "ride on"?
   / Convert walk behind snow-thrower into a "ride on"?
Thanks duwem.:cool2: What I'm taking away from that video is that the 29/30/31 inch machine with 10hp has the traction to pull those guys. I'm heavier than either of them but not both.:laughing: I'm thinking I will start with the trailer/sulky first. The blower I'll use had an 8hp engine which I'll repower with a larger heavier one. Also try running the blower at higher speed to send the white stuff far enough so the sides of my cut stay lower.
   / Convert walk behind snow-thrower into a "ride on"? #13
Some Chains and or wheel weights may be necessary to do some actual work with you attached.
At some point you will find the weakness of the transmissions drive system. If its a friction drive, you may need to add some extra springs to prevent the disk from slipping and wearing quickly?? if its an old gear drive you may be ok, but a lot of snowblowers dont have bearings, just brass bushings or even shafts running right in the sheet metal.
This project will be for summer. The blower I want to use is under snow in the back forty. Several feet of it. I can't remember what kind of drive it has. I'll make sure the bearings/bushings are going to take any added load I'm giving them, thanx. To repower it I'll watch the sales at Princess Auto for the diesel engine they carry.
   / Convert walk behind snow-thrower into a "ride on"? #15
kijijji and look for a cheap 10 HP show blower .... with motor OK but won't drive, broken parts / rusted bucket ....
or look for one with tracks and individual track controls (left and right) for steering.
   / Convert walk behind snow-thrower into a "ride on"? #16
Love it ,purty place .
I say go for it, I like the articulated design. Now how to get power to the rear axle? A driveshaft? Put chains on all four wheels and you should be all set. maybe convert the front wheels to tracks and just have skis or rollers on the rear "sulky".
A friend of mine has some old Hus ski snow machines, tracks up front and skis in the rear that you sit on.
Home Bolens Hus Ski and Diablo Rouge
This is what I'm looking for advice to give me ideas. Even if the blower drive can handle another driven axle, I need to make sure auxiliary axle is the same speed. I'm hoping that at the low speeds I'll be driving this, solid drive axles won't matter too much while cornering. Thoughts?
   / Convert walk behind snow-thrower into a "ride on"? #18
As long as the two axles are geared the same I don't think you would have any problems turning with a straight rear axle on an articulated rig.
Make sure you set the skids on the blower so the main scraper isn't contacting the ground.
Take a look here
articulated snow blower - Google Search
   / Convert walk behind snow-thrower into a "ride on"? #19
What about using 2 similar snow-blowers. Same age, make, model, bucket size, engine h. p. speed range, etc, Rig them up like an articulated tractor. Use 1 ahead for front wheel drive and snow-blowing. Use the rear 1 for additional power and help in propelling the unit forward.
As was posted earlier find one that has a bad front blower or exploded gear case,(extra parts) but with a good drive train.
Maybe make a short wheel base sulky type, putting a seat on the rear 1 above the motor for weight and help with traction and still be able to reach the controls on the front 1.
Use a foot pedal for tightening the belt.
Make a console on the side for the throttle,electric start, and gear selection.
Might be able to do it this summer, with the snow ending soon.
This way you could start building if it dosen't look right take parts off and re-do it to your liking.
Just a few thoughts from this old mind.
T. J.
Take a look here
:laughing:
Scrolled through that link! I think the only thing not in there was someone with a shovel in their hand!:laughing::laughing:
2023 CAN-AM HD7 RTV (A59823)
2023 CAN-AM HD7...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Kubota L3130 (A53317)
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
Jaw Crusher (A59228)
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
