Cab and heat for the BX2350
   / Cab and heat for the BX2350 #1
PA-Kubota
Member
Apollo PA
2008 BX2350
I'm getting older and like warm things now. Who sells a heated cab or has plans so I may make it?
   / Cab and heat for the BX2350 #3
   / Cab and heat for the BX2350 #4
I always like to go low tech and el cheapo when possible. Get yourself a cab and then look at heaters for golf carts. They are gas heaters that run on little LP tanks. I just saw one listed on a golf site for $80. That might be the ticket. In reality, a cab really raises your surrounding air temp without any heat. I find that most times in my cabbed B3030, I turn the heat off because I'm too hot.
Good luck.
   / Cab and heat for the BX2350 #5
Do a forum search and you can find a number of options. There's essentially a few different cab options available in the US/Canada from Laurin, Sims, Jodale Perry, and Curtis. The Curtis cab is probably your cheapest option. (If you're based in Europe, then other options exist.)
Here's a good starting thread with pictures of several of the cabs installed on the BX2350:
http://www.tractorbynet.com/forums/kubota-owning-operating/114242-bx2350-24-laurin-cab.html
Tektite (out of Canada) - makes a pretty slick looking cab for the BX tractors also.
ROPS Tractor Cab Manufacturing by Tektite
UNUSED 4000PCS 12 in. Zip Ties (A50860)
UNUSED 4000PCS 12...
71062 (A49346)
71062 (A49346)
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2012 Big Tex 14GP-24 Gooseneck Trailer (A50860)
2012 Big Tex...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
Lift station Pumps (A49461)
Lift station Pumps...
