Cab and heat for the BX2350
   / Cab and heat for the BX2350 #1
PA-Kubota
Member
Apollo PA
2008 BX2350
I'm getting older and like warm things now. Who sells a heated cab or has plans so I may make it?
   / Cab and heat for the BX2350 #3
   / Cab and heat for the BX2350 #4
I always like to go low tech and el cheapo when possible. Get yourself a cab and then look at heaters for golf carts. They are gas heaters that run on little LP tanks. I just saw one listed on a golf site for $80. That might be the ticket. In reality, a cab really raises your surrounding air temp without any heat. I find that most times in my cabbed B3030, I turn the heat off because I'm too hot.
Good luck.
   / Cab and heat for the BX2350 #5
Do a forum search and you can find a number of options. There's essentially a few different cab options available in the US/Canada from Laurin, Sims, Jodale Perry, and Curtis. The Curtis cab is probably your cheapest option. (If you're based in Europe, then other options exist.)
Here's a good starting thread with pictures of several of the cabs installed on the BX2350:
http://www.tractorbynet.com/forums/kubota-owning-operating/114242-bx2350-24-laurin-cab.html
Tektite (out of Canada) - makes a pretty slick looking cab for the BX tractors also.
ROPS Tractor Cab Manufacturing by Tektite
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A48081)
2001 Sterling...
2012 KENWORTH T800(INOPERABLE) (A48992)
2012 KENWORTH...
2020 PETERBILT 579 TANDEM AXLE SLEEPER (A45679)
2020 PETERBILT 579...
2015 Ford F-250 Pickup Truck (A48081)
2015 Ford F-250...
2021 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2021 JCB HM180T...
Hay Spear Attachment (A48837)
Hay Spear...
