Amco Offset Disc
   / Amco Offset Disc #61
What a great rebuild thread and a fine job that you are doing.
   / Amco Offset Disc
Thanks Sixdogs. But sometimes I go overboard. Years of learning from Dad and honing that skill rebuilding wrecked helicopters! Because you may never get a chance to redo your work. Redos are harder to fix than doing the job right the first time anyway!
hugs, Brandi
   / Amco Offset Disc
Friday I installed a new Oil/Water Separator and made a wood frame I could move over the disc. 3-29-13 Air Oil Seperator with Regulator.jpg I put plastic over it to keep the pollen and dust falling down from the ridge vents.
Saturday afternoon I started painting. The white suit really did a good job protecting me, but I could not move around easy on the creeper.3-30-13 Painting on the Creeper.jpg The air hose was the only pain I had in painting. The siphon cup gun worked way better than expected. I had no problem spraying overhead. This gun has a small clear tube that goes from the cup vent hole up into the arch that holds the cup's lock mechanism. So no drips. However, there was a paint leak somewhere that had my rubber gloves covered in paint overspray. I did have some problems with the straight fitting off of the air hose with the disposable filter added. Next time I will install a hose swivel.3-30-13 Paint Gun and Me in White Suit.jpg
I had put my floor fan in the doorway and closed the door up to the fan and only had my side door open. This seemed to work well moving overspray out. I added the hardener to the paint and had no problems with it's use, along with the recommended reducer.
I had the tongue hanging from my loader out in the sun and it was hard to a lite touch at dark.3-30-13 Painted Tongue Hanging.jpg I started painting it at 4:30. So 3 hours went by. The paint instructions says wait 24 hours to work hard with it I had no problems with runs either. Only way I could get a run was to stop fanning the gun and spray in one spot..............which I didn't do.
I went ahead and used $15 of thinner to clean the gun. So I'll use it again then toss it. I also mixed too much paint and wasted about a quart, while about 1.5 quarts are still in the can.
hugs, Brandi
3-30-13 Disc and Tongue Painted.jpg3-30-13 Disc Right Front Painted.jpg3-30-13 Disc Right Side Painted.jpg3-30-13 Disc Rock Shaft Painted.jpg
   / Amco Offset Disc #64
Now that is a professional looking job. Great paint coverage and excellent prep work with nothing left to chance.
The prior owner wouldn't recognize it.
   / Amco Offset Disc #65
Nice job and great thread. I have disc envy.....
   / Amco Offset Disc #66
Brandi, can you come visit? You've got the neatest shop I've ever seen!:thumbsup: Maybe you could teach me how to do it:confused3:
I nominate you for the Neatest TBN Shop EVER award.
   / Amco Offset Disc #67
Question : Are those Your real eyes or the Stars in the Texas Sky ? :hot:
Boone
   / Amco Offset Disc
Sixdogs,
Thanks a bunch!:D
Hahaha. I had to laugh.:laughing: I forgot:eek: tack rags and had to wipe it down with shop towels. I ran out of them and had to use paper towels out of my kitchen. The towels would leave little specs all over where rough spots are in the metal.:mad: So I just wiped down the top and painted.;)
I could not believe how that paint sprayed and didn't "stack up" and run. Great paint.
hugs, Brandi
   / Amco Offset Disc
Thanks John. The secret of a neat shop is having 3 stalls just through a sliding side door full of stuff that litters a shop up.;) That and a neat junk pile out back!:rolleyes: I hate working it tight spots, so my work area is always clutter free.:laughing: I guess years of dealing with FFA inspectors trying to justify their jobs by writing up untidy hangars finally paid off!
Thanks for the nomination!:thumbsup:
hugs, Brandi
2011 GMC Yukon XL Denali (A56859)
2011 GMC Yukon XL...
378813 (A51573)
378813 (A51573)
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2017 FREIGHTLINER...
UNUSED SDLANCH SDLL60 STAND ON SKIDSTEER (A57192)
UNUSED SDLANCH...
2007 Yard Dump Truck (A55973)
2007 Yard Dump...
2013 Dodge Charger Sedan (A55853)
2013 Dodge Charger...
