3pt chipper will not lay flat
   / 3pt chipper will not lay flat #11
I like the skid idea if you don't mind the machine being raised slightly.
Or, perhaps you could move the hitch pins on the chipper to where you want them.
   / 3pt chipper will not lay flat #12
I recently purchased aBX62R and encountered the leveling problem,so I installed a hydraulic top link.Now the chipper sits level and the vibrations are greatly reduced.The unit is mounted on aJD 5105M and turns at 540rpm at 1750 engine rpm in the pto e mode.The hydraulic feed is definitely the way to go-my helper snagged his glove on a feeding branch and I disengaged the feed drive before it could pull him in.I never operate this beast alone;my position is always at the feed control bar.
   / 3pt chipper will not lay flat #13
No issues with the BX-42 on my Kubota B2920. I have to tighten/shorten the top link to drive on/off my trailer without dragging the back of the chipper, but once out in the woods, I loosen/lengthen the top link and can always get the chipper flat on the ground. No problems attaching or detaching from the three-point either, though I do store it on a pallet to keep it off the ground.
   / 3pt chipper will not lay flat #14
First, lock tractor brakes "on" and lower FEL all the way to the ground, then put a 4" - 5" diameter ROUND branch under the support stand, in middle or slightly biased to the rear, and chip away. I have been carrying around my "favorite" 5" chunk of branch since the Wallenstein was new.
This morning used the Wallenstein BX42 to mulch a Flatwoods Plum along the Nature Coast State Trail.
Note my "favorite" branch under the chipper base. It is nothing fancy.
Also a photo of how I secure the chipper end of PTO shroud chain #2.
   / 3pt chipper will not lay flat #15
I think you just need to buy a shorter toplink at tractor supply. The chipper has a long base that extends pretty far out from the lift arms.
Regards,
Chris
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2016 Nissan Altima 2.5 Sedan (A54815)
2016 Nissan Altima...
KSI Conveyor (A53473)
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
UNUSED Folding 4-Step Stool Ladder (A53117)
UNUSED Folding...
