dsmiley
Gold Member
Panik, a little off topic here, I bet you took those photos with an Iphone. If so, take them with the volume buttons down and they will transfer to PC stuff in the proper orientation.
Dean
Dean
In regards to the iPhone photo advice - not off topic at all considering I was asking you folks to look the condition of my field.
In any case I do for see a visit to northern tool as well as tractor supply. The wife's talking about putting in fencing, as well as improving the land so that we can eventually put a horse on it.I think she's got higher expectations of my long term abilities than I do.
I've got one of those as well................ a wife with high expctations.
Let's face it.... we're screwed :confused3:
Well, I ended up "mowing" part of the field in order to mark the section I decide to keep uncultivated as its getting close to time to start working the field. I say mowed, basically I set the the deck just short of as high as it could go, took it slow and top cut everything. However I will be getting the field brush hogged to deal with the corn stubble.
In a related note I need a bit of reassurance. My dealer couldn't find the manual for my tractor and won't be able to get one to me until next week. When I mowed my actual lawn, prior to tackling the field, I couldn't get an even cut until I ran things up at 3000rpm. I didn't realize there was a break in period and that your weren't supposed to be running over 25,000 to 27,000 rpm.
I'm guessing its bit paranoid, but should I be concerned about this? The only thing I picked up on is that when I top cut the field the engine temp was about halfway between the mid point and the start redline I was done. the fan shroud wasn't blocked. I did vary rpm's pretty frequently doing the field and lawn simply due to getting used to the machine.
