Photos of tractors on Hills
   / Photos of tractors on Hills #21
wow DT86, that second photo. Did you go down forward then backup the hill? Are your tires loaded?
   / Photos of tractors on Hills #22
I recently purchased my L3540 and it definitly feels alot more tipsy than my B2920. I wouldnt all my property "hilly" but it is definitly not flat. Post some photos of your tractors on hills. Not on inclines and declines. (although those would be fun photos to see as well). So whatever tractor you have, Large or small, I'd like to see some hill shots.
Sorry, don't have any photos of my tractors on hills since my 10 acres is flat pasture. BUT, if I had hills I'd use my 1964 MF135 diesel to mow those suckers.
It's set up to squat low for work in the olive orchards around here. The rear tires are BF Goodrich 6 ply 18.4-16A (18" wide, 16" dia rim, 40" tall overall, loaded with water). The rear wheel track measured to the outside of the tires is 83" and the centerline of the rear axle is 20" above grade. The front axle spindles have been shortened to keep the tractor level.
Good luck.
   / Photos of tractors on Hills #23
The first picture shows the same hill as the second one, prior to being mowed. I go up forwards actually. If you click on the picture to make it bigger, then click on it again to zoom-in you can see the tire tracks.
I was using a M125x Kubota with the rear tires loaded and the loader on, minus a bucket and a 10' Deere pull type cutter
   / Photos of tractors on Hills #24
Northern Minnesota is pretty flat. The closest thing to what might be construed as a hill would be a sand ridge. Our farm is built on the side of a sand ridge with the buildings and pastures on the ridge, while the fertile crop land is on the flat, drained swamp below. I think this is the only hillside picture I have, as most of my tractor work is done down on the flats. Not much to it after seeing some of those other posts!
Joe
   / Photos of tractors on Hills #25
I don't have any pictures of it on a hill currently but I have a picture after I mowed the hill.
Well did find one from the tractor.
   / Photos of tractors on Hills #26
Did you post a video of mowing that?
   / Photos of tractors on Hills #27
Yes I did before.
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2014 Kubota B2320 (A50123)
2014 Kubota B2320...
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
2025 K731G UNUSED Flower Bed (A53117)
2025 K731G UNUSED...
2018 WACKER NEUSON EZ36 EXCAVATOR (A51246)
2018 WACKER NEUSON...
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
