Thinking of a top and tilt setup
/ Thinking of a top and tilt setup #1
jim_wilson
Northeast MA
Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
I have some grading I'm going to have to do on my property - and while contemplating which box blade to get, I also started thinking I might want to put a top and tilt setup on the tractor too (Kubota B3200).
I have the tractor setup for a backhoe - so there are hydraulic ports at the back I could use to feed the top and tilt setup.
I've seen a number of different configurations for hydraulics on the 3pt, top cylinder only - cylinder on just one of the 3pt arms , cylinders on both of the 3pt arms, etc.
What I would like to be able to do - is get a loader joystick - and use that to control the top and tilt - one axis for the top link cylinder - and one axis for the arm link(s) cylinders.
Is there any reason why this won't work?
Is there a reason to have cylinders on both of the 3pt arms and not just one? I'm thinking the joystick setup would work ok for the following configurations:
1) Top link cylinder and just one arm link cylinder
- or -
2) Cylinders on both of the arms - controlled by the joystick - and then a separate control for the top link.
Another concern: The tractor has a warning that the 3pt should not be operated if the backhoe is connected - "because it might damage the backhoe controls" - am I correct in assuming this is just because the backhoe valves must not have a pressure relief - and I would not have a problem running the hydraulics for the top and tilt from the backhoe feed - as long as the valves I used to control the top and tilt had a pressure relief ? (so I could use the 3pt while using the top n tilt fed from the backhoe ports)??
/ Thinking of a top and tilt setup #2
The valve that feeds the BH will have a pressure relief.
The BH valve itself probably has a relief.
There is no need to use the 3pt while using the BH. You are probably using the hyd for the 3pt to feed the BH.
One cyl for the Tip, and one cyl for the Tilt. The tilt cyl will move the lift arm above and below horizontal.
Check with
Brian
Top and Tilt Kits by Fit Rite Hydraulics
http://fitritehydraulics.com/
The joystick valve will probably have float and that will be useful.
/ Thinking of a top and tilt setup #3
I've had a hydraulic top cylinder for a few years and really find it useful. Just ordered a tilt cylinder from Fit Rite two weeks ago and am looking forward to its arrival.
I have a Deere 4100 and had the dealer add two valves a QD that are supplied by the power beyond port. That's been working well and the second valve will be used for the tilt. Two tilt cylinders would seem to allow a greater range of adjustment, if nothing binds. I think one will be adequate, at least for me.
Check with
Brian
Fit Rite Hydraulics - fitritehydraulics.com
I guess what I was concerned about was the premise behind the warning - that trying to use the 3pt controls while the backhoe was attached - would lead to damage on the backhoe valves - without looking into it more - that would lead me to believe that the backhoe valve block has no pressure relief.
It also makes me wonder how - if I use the hydraulic pressure port(s) that normally feed the backhoe - to feed the top and tilt setup - will the 3pt work correctly?
I do know that the loader and the backhoe circuits are independent of each other - I can operate the FEL and the backhoe at the same time. The thing I don't know is "how" separate the backhoe and 3pt circuits are. When the backhoe is removed the circuit that normally feeds it is looped back (hose with male is plugged back into the female of the pair of connections) which I assume is because it needs to be that way in order for the 3pt to work properly
I've already contacted FitRite about one of their setups. I'll ask about the valve also.
My idea behind using the joystick setup was that (like you pointed out) - it would have float - but also it would allow for easy intuitive adjustments on the top-n-tilt setup. One axis for the toplink cylinder - one axis for the other cylinder.
/ Thinking of a top and tilt setup #5
Most BH valve will have a relief.
I was trying to point out that use of the 3pt arms might damage something. You would probably never use the 3pt when the BH is installed.
You may even be bypassing the 3pt system.
If the FEL is using all the pump fluid, there should be none left for the BH. If you use part lever for the FEL, then there is fluid for the BH.
All valves should be in series, and the up stream valves have priority.
/ Thinking of a top and tilt setup #6
I will second the get ahold of Brian at Fit Rite Hyd. and see what he would suggest. I have his set up on my tractor and it works very well. Brian has a wealth of information about this set up.:2cents::thumbsup:
/ Thinking of a top and tilt setup #7
I am looking into the same thing for my BX 25. First step-Get the BX Shop Manual before you even think about it. That is the only way you can really understand how your hydraulics work. The BX 25 only has one main relief valve. The BH works through the PB, that is why both it and the FEL work at the same time. I do not understand why you are worried about the 3PT W/BH on. You can do nothing else with it. I park it in the up position,and close the valve below the seat, and leave it alone when BH is on. If the arms come down they can get in the way of the BH. You will need a valve set made for PB and then connect all three hoses (P-PB-T) same as the BH. Everything then works. W/O the PB connected the 3PT and FEL won't work. Get the manual and trace out the circuit. While you are at it put some more shims in the RV and increase your pressure. Get the gauge from SC, a steel tee and M/F connectors at your local supplier. Install the gauge in the branch side of the tee. Put the tee with gauge in the PB line to monitor pressure as you raise it. I went to 2000 PSI and it sure made a difference.
Ron
Ron
Please go read what I wrote again. I'm not going to use the 3pt at the same time I'm using the backhoe - I'm wondering what I have to do to safely use the backhoe feed ports to feed the top and tilt.
Here's the source of my concern - the Kubota manual for the BH77 backhoe has the following warning(s) in it:
It is necessary to have the backhoe detached when using the rear remote, the 3pt hitch or any other valves that are downstream of the backhoe valve. Failure to do this may cause the unit to exceed the allowable back pressure resulting in breakage of the seal or case of the backhoe valve.
Backhoe must be removed when using any rear remote valve, 3 point hitch, or any hydraulic component that is downstream of the backhoe valve. Failure to follow this instruction will result in valve damage.
When backhoe is attached, make sure to properly secure the hydraulic control lever (3pt lever) in the "DOWN" locked position, Accidental operation of the hydraulic control lever can result in valve damage.
Those warnings are where my concern is coming from.
I would like to just use the backhoe feed and return lines to feed the top and tilt setup. But the factory warnings seem to indicate that if I use them to feed another valve - and I use the 3pt at the same time (which I would be doing with the top and tilt) - I would get valve damage.
Is there a way to set this up to avoid the damage that Kubota is warning about?
What has Kubota done with their backhoe valve setup that makes it susceptible to damage - if the 3pt lever is moved and the backhoe is attached?
I'll see if I can get a scan of the schematic in the Kubota manual that illustrates the B3200 hydraulic setup.
Maybe that will make it clearer.
/ Thinking of a top and tilt setup #10
I do not have any of that language in my BX25 Operators manual or workshop manual so here is my rational: It is necessary to have the backhoe detached when using the rear remote, the 3pt hitch or any other valves that are downstream of the backhoe valve. The other valves are downstream only when the BH is connected via the PB line. The backhoe will be disconnected and all the valves out of the system if doing any of this. Failure to do this may cause the unit to exceed the allowable back pressure resulting in breakage of the seal or case of the backhoe valve. Yes there is a relief valve in the BH valve system but it has no effect on downstream pressures via the PB.
That is why I close off the valve that controls the 3PT speed.
Rational: Once the BH is disconnected all the BH valves go with it so are not in the circuit. You are now with P-PB-T lines with the P and PB connected together to complete the power circuit and the tank line blocked off. You are adding a new valve array to that 3 line hook up same as it you were using the BH valve array. The top and tilt cylinders are the same function as the FEL and it does not have a relief valve as no excess can be developed by the operation like a BH can develop.
Remember Kubota has to have language in their manuals to protect their liability when people do stupid things. These statements lose relevancy when knowledgeable people do mechanically sound modifications. Kubota does not even offer rear remote systems for the BX, they are all after market modifications. In fact the dealer I bought my BX from stated they would not do any modifications that were not supported by Kubota parts and manuals and their reason was liability. I think you are safe and sound to proceed.
Ron
/ Thinking of a top and tilt setup #11
Jim,
The BH feed line is the source of fluid for the BH, or the remote valve.
You are probably using the feed line from the hyd block to feed a QD for the BH. If not using the BH, a jumper hose would connect the PB QD to the 3pt or the remotes.
The 3pt is not in the circuit unless you have gone to the effort to insert the BH valve in series with all valves.
To install or use your remotes, the BH QD would feed the IN port of the remote valve, and the PB from that valve would feed the 3pt, and the OUT port would go to tank.
Once you have the remotes installed, then the PB from the remotes become the FEED line for the BH, and the 3pt is out of the circuit.
If you want to use the BH and not use the remotes, then disconnect the remote input QD and use that QD for the BH.
The only problem I can see is if the BH valve does not have a high pressure port for the fluid going to the 3pt if you onnected all valves in series.
Most OUT ports are limited to about 500 psi, so if all valves are in series, and then by operating the 3pt, it may cause the 2500 psi to back up through all the valves, and perhaps cause damage the BH valve.
So to alleviate any problem, just bypass the remotes and 3pt when using the BH. The BH OUT port can go directly to tank
When using the BH, there is no need for the remotes or 3pt.
/ Thinking of a top and tilt setup #12
Jim,
Something I may have missed in my rational; Is your BH control vale assembly permanently installed on the BH unit or on the tractor? My BX; when you unhook the BH, the valve assembly goes with it. I was assuming your 3200 was configured similar to my BX. Sorry I may have mislead you. All the more reason to have the Workshop Manual. If you have it; scan and post the HYD diagram and the experts here like JJ can trace it out for you, if you need help deciphering it.
With my setup I would have a new valve assembly that is only connected and used when the BH is unhooked. That way the 3PT and FEL is still downstream of the new valve.
Ron
Jim,
Ron
Yes - my tractor is setup differently. The valve for the loader is located under the seat - and stays "attached" to the tractor when the loader is removed. The joystick is right next to the seat - the valve itself is under the seat - and the lines feeding the loader go under the operator platform to a bracket where they end in quick-connects to attach to the hoses from the loader.
Jim,
Aahhh - Ok, I think this is making sense now. I had to read it a couple of times for it to sink in though.
I believe the current setup is as so:
There is a distribution block under the seat area on the tractor. The feed from the hydraulic pump feeds that block - which then in turn feeds the loader valve - and the pipe with the quick connect on it that feeds the backhoe.
Then - there is another quick connect at the back of the tractor - that goes to a pipe that feeds directly into the side of the 3pt block(valve?). When the backhoe is disconnected - the two QD's that normally connect to the backhoe - are just jumped together so the fluid flows directly to the 3pt block. When the backhoe is connected - trying to operate the 3pt must cause some sort of backpressure in this system which can damage the valves in the backhoe - which although they may have pressure relief - have nowhere else to dump to - except for that feed into the 3pt.
So what I need to do is find a way to feed the out port back to the tank. There are some unused ports on that distribution block I mentioned - I'll have to take a closer look at that to see which ones might dump back to the tank. Once I figure that out - I can run a hose or pipe out - put a QD on it - and make it the return or out line.
Then I'd be able to hook up a joystick - or some spool valves - to the QD's on the three lines - make sure the power beyond feeds the 3pt - and the Out port goes back to the tank - and it should work - and this will avoid any damage issues because the pressure relief will dump to the "out" port.
Do I have this correct?
/ Thinking of a top and tilt setup #15
Jim,
I've been looking into this too for my B3300SU and I'm still a bit confused about the three point needing locked in the down position when the backhoe is installed. If you look at the this diagram http://www.tractorbynet.com/forums/...00su-pb-bh-rear-remotes-hydraulic-diagram.jpg it looks like the 3pt valve passes fluid to the tank in both the neutral and down positions of the valve, only in the up position does it not provide a path to the tank. I suspect you are right about the tank port being one of the plugged ports on the loader valve, I think a return/tank line from a rear remote valve body could be tied into that valve body if we know which one to use.
I think the biggest obstacle is where to put the rear remotes - there is really no room when the backhoe is mounted to hide a remote valve setup anywhere. I don't what to mount it on the fender or ROPS if I can avoid it, I don't like the looks of it and I think it's just waiting to get caught by a tree branch or such and rip the hoses off.
/ Thinking of a top and tilt setup #16
Sounds like it you have it.
What I would do (assuming that the backhoe is connected with a flexible line) is to take the line that currently feeds the backhoe "In" and run that to the "In" on your remote block, the run the "Out" from your remote block to the "In" on the backhoe. I would take the "Tank" port on your remote block and feed it directly into the tank (through the filler port?).
Then your new remote block is upstream of the backhoe and cannot hurt the backhoe block.
Aaron Z
Jim,
My thoughts were that what I wanted to do - was to first figure out the actual hydraulic plumbing - and where to mount the lines and QD's. I've got to look the tractor over a little more when I get home tonite. It's going to be tough to find a place to put another line with a QD end on the back of the tractor - the current factory Kubota setup with the two backhoe connections is already sort of cobbled together IMHO.
Yeah - I don't like the idea of just hanging stuff off the back of the tractor like I've seen in some installs - I'll rip a hose off on a tree branch or trip myself off the tractor getting my foot caught on a house while I climb around the backhoe or something like that. I'd like to have a nice clean install for the all three of the quick connections.
As far as for controls - what I was thinking of doing - was setting this up somehow - so that I could use a joystick in cases where I wanted one - or use a regular valve in cases where I wanted that. That's why I was wanted the quick connections - so that I could swap out controls depending on what implement or use I had at the rear end of the tractor. As an example - I think there's enough room along the side of the seat to get a joystick controller in there without it being in the way - something like this:
https://www.surpluscenter.com/item.asp?item=9-7401&catname=hydraulic
My idea is to have it setup with the hoses or lines arranged in such a way that they're nice and clean. That might involve some custom bended hard lines to make it work - that's something I need to look into some more. I spend some time researching making hydraulic lines last year - as well as the feasibility of bending hard lines - and it doesn't look all that hard - it's more a matter of getting the right tooling (benders, etc).
/ Thinking of a top and tilt setup #18
If you only have 2 qd on the back it's just a pb with a high pressure return to the 3ph. You'll need to find/create a low pressure return to tank for the out flow from the valves.
That's the missing piece I did not know , JJ's post #11 set me on the right track to figuring that out.
I've been going back and forth tonite reading the manual and cross referencing by running out to the barn to look at the actual tractor, and I think this has helped me to get this all (mostly) figured out - I hope.
After going back and forth and finally crawling under the tractor to take a look - I did find a port where I might be able to cut in for the tank return. The manual showed a "tank" port on the loader valve block - but I had to crawl under the tractor and really look before I could see it.
There is a what defintely appears to be a lower pressure hose (it's painted over but I can see the weave coming thru the paint) - which is attached to the loader valve block with a hose clamp - and it appears to go into the side of transmission case - which is where I assume the resevoir is.
Which leads me to another question - can I just splice into this line - or add a block or something (to accept more "tank" or "out" lines) - so all of my "outs" will feed back into this port? Do I have to worry about backpressure at all or is this low enough pressure that there should be no concern there.
I'd like to add some more hydraulics to the front of the tractor also - and my I want them to be active at the same time the loader is active - so I was going to do something like use a Fasse valve on the backhoe line - to feed hydraulics forward for the additional valves there. Those valves will also need a return "tank" line. If I plumb all of this into a block or something - which then in turn feeds the tank - will I have any issues with backpressure affecting anything dumping into that common return block?
/ Thinking of a top and tilt setup #20
An easier way to get the 3rd function on the loader is a diverter valve on 1 of the control line sets. Much cheaper also. Also wouldn't mess with the BH at all.
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
(16) WOOD PALLETS (A60432)
(16) WOOD PALLETS...
207276 (A52708)
207276 (A52708)
LOAD OUT AND SHIPPING (A61166)
LOAD OUT AND...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
Teak Wood Dining Table (A59231)
Teak Wood Dining...
