Kubota B2650 & B3350
   / Kubota B2650 & B3350 #12
FYI. Its skid steer "STYLE" QA. Its not compatible with SSL implements.
From the pic in the brochure - which I admit is hard to really get a good feel from - it looks skid-steer' ish.
What did they do that makes it incompatible with skid steer implements? Is it width - or heigh incompatible? - or both?
Part of the reason I (personally) - would prefer a skid steer style QA - even if it wasn't directly compatible with most skid steer implements - is because 1) - I think a skid steer style QA would simply be quicker to use in swapping out implements (and I have seen setups where the locking pin can be electrically or hydraulically actuated - which makes it into something you never have to leave the seat for) - and, 2) - because even if I had to weld up an attachment to have it fit on the QA - it's just easier to do that with a skid steer style - than it is to have to weld the brackets on for the current QA (pin on style) - that is available on the Kubota B series.
I have found after using the Kubota B-series pin-on QA for a year now - that it's not bad - but I rarely can just pull the pins and go - or insert them and go. I carry a hammer with me and I usually have to knock them out to get the attachment off. Not a huge deal - just a bit of pain in the butt sometimes.
I agree that it looks more skid-steer-ish from the picture. Although, I don't know that it's compatible with other standard skid-steer QA attachments.
Either way, it does look easier to change attachments than the Kubota pin style QA that I have now (the pins aren't always easy to get installed.)
   / Kubota B2650 & B3350 #14
The local dealer has a 2650 on the lot and I stopped and took a look at it sat. They didnt get a bucket with it to install on the loader, and i don't think he opted for the QA which is what i was hoping to see maybe he'll get one on the 3050. The cab is nice, but $21,200 is a bunch + 3200 for the loader., that's $9000 more than a 2620.
I did notice a nice ratcheting lower link adjuster on the 3PH that wasn't mentioned in the brochure, I should have took a picture of it..
To be fair, a better comparison would probably be to compare the B2630 to the B2650. The difference will be much less after you subtract the cost for the cab. There's a number of other differences between the B2620 and the B2650 besides having the same horsepower.
As for the 3PH, I noticed that too. Here's a picture I took of the B2650 when it first arrived my local the dealer:
For what it's worth, here's the rest of the pictures that I never got around to posting in case anyone is interested.
IMG_0629.JPGIMG_0630.JPGIMG_0631.JPGIMG_0632.JPGIMG_0633.JPGIMG_0634.JPGIMG_0636.JPGIMG_0637.JPG
   / Kubota B2650 & B3350 #17
I've been looking into upgrading the 3pt setup on my B3200 (so I've been doing some research) - and it looks like what Kubota is doing - is they're shipping the B50's with the deluxe 3pt setup that used to be found on the B2910 B3030 - etc. . There's a ratcheting adjusting link, telescoping stabilizers (instead of the turnbuckles) - and extendable lower arms.
Looking at the Kubota online parts listing and comparing some part numbers between a B2910 and the B2650 - and the 3pt parts are all the same exact part number.
I actually upgraded the turnbuckles on the stabilizers of the 3PH on my B2620 to the newer adjustable style a while back. I never thought about doing the telescoping stabilizers, but perhaps it's possible. I never looked into it too closely. Although, I suspect you're right and that most of the part numbers are probably the same.
Here's a picture of my B2620 3PH after the upgrade:
   / Kubota B2650 & B3350 #19
After looking closely at these pics, that appears to be the exact 3pt setup on my B2630. It is a sweet setup. Works flawlessly.
   / Kubota B2650 & B3350 #20
Don't you have the extendable end links on the 3pt lift arms?
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2000 INTERNATIONAL 9200 (A52472)
2000 INTERNATIONAL...
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
