855 anti freeze overflow leak
   / 855 anti freeze overflow leak #1
gregz
Hoosier
BX 2350
JD 855 after gettting up to operating temp leaks anti freeze from overflow tube. I replaced cap with oem JD, same issue. I havn;t run tractor long enough to see if major overheat problem. Maybe install new thermostat?
suggestions welcome
thanks in advance
gregz
   / 855 anti freeze overflow leak #2
You can't fill your rad to the neck, the coolant expands when it gets hot and if there's no room in the rad the rad cap spring opens up and it spits out of the overflow. You might just have to much coolant in it.
But check the basics to ensure you have no oil in your coolant and vise versa.
   / 855 anti freeze overflow leak #3
suggestions welcome
thanks in advance
gregz
Is it just too full? Mine runs down about an inch or more from the top.
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A56438)
2019 BOBCAT T630...
John Deere Gator (A53317)
John Deere Gator...
2009 Cadillac CTS Sedan (A59231)
2009 Cadillac CTS...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
