Want to make ball hitch attachment for the three point lift, Any made?
   / Want to make ball hitch attachment for the three point lift, Any made? #1
Ehanson
Kamloops, B.C.
S373-D
I have a Cat 1, 3 Pt Hitch, I want to put a ball on a cross member and mount it between the lower arms of the 3PH.
Any have any pics of one they have made?
I will build it, but I am thinking of hitch geometry and such?
Thank you
   / Want to make ball hitch attachment for the three point lift, Any made? #3
We make a receiver hitch for pull type trailers and a model that works for pull type and gooseneck trailers. The receiver for pull type trailers is available in a standard and subcompact model. The gooseneck receiver is Category 1 quick hitch compatible. All of our receiver hitches ship free to your home within 1,000 miles of Newton, NC. If you're outside the free zone, just give us a call for a quote.
Travis
   / Want to make ball hitch attachment for the three point lift, Any made? #5
Here is one that I did as an early welding project. The welding could be a lot better, but it will give an idea of one approach. Note, the weight and pull is on a heavy duty drawbar, so it should hold. My welds are just keeping it upright.
   / Want to make ball hitch attachment for the three point lift, Any made? #6
Here's the thread I posted after making mine: My 3 point trailer hitch project
If I were to do it again, I would put the hitch on the inderside, then bolt through the drawbar into a plate on top, which I would weld the vertical part.
Jim
   / Want to make ball hitch attachment for the three point lift, Any made? #7
You either need to get one like others have posted, or you need an anti-rotation bracket if you only use the lower arms like you are talking about doing
   / Want to make ball hitch attachment for the three point lift, Any made? #8
Thank you
I liked this design so much that I bought one! :)
The top receiver makes it very versatile.
Got it from: OMNI Mfg LLC
   / Want to make ball hitch attachment for the three point lift, Any made? #9
   / Want to make ball hitch attachment for the three point lift, Any made? #10
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A48992)
2008 V.E...
2009 TROXELL KILL TRAILER (A48992)
2009 TROXELL KILL...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
Pallet of (11) 10 Lug Misc Wheels (A48837)
Pallet of (11) 10...
1998 FORD F-800 (INOPERABLE) (A48992)
1998 FORD F-800...
Diamond Mowers 6ft Rotary Brush Cutter Skid Steer Attachment (A49346)
Diamond Mowers 6ft...
