Want to make ball hitch attachment for the three point lift, Any made?
   / Want to make ball hitch attachment for the three point lift, Any made? #1
Ehanson
Kamloops, B.C.
S373-D
I have a Cat 1, 3 Pt Hitch, I want to put a ball on a cross member and mount it between the lower arms of the 3PH.
Any have any pics of one they have made?
I will build it, but I am thinking of hitch geometry and such?
Thank you
   / Want to make ball hitch attachment for the three point lift, Any made? #3
   / Want to make ball hitch attachment for the three point lift, Any made? #5
Here is one that I did as an early welding project. The welding could be a lot better, but it will give an idea of one approach. Note, the weight and pull is on a heavy duty drawbar, so it should hold. My welds are just keeping it upright.
   / Want to make ball hitch attachment for the three point lift, Any made? #6
Here's the thread I posted after making mine: My 3 point trailer hitch project
If I were to do it again, I would put the hitch on the inderside, then bolt through the drawbar into a plate on top, which I would weld the vertical part.
Jim
   / Want to make ball hitch attachment for the three point lift, Any made? #7
You either need to get one like others have posted, or you need an anti-rotation bracket if you only use the lower arms like you are talking about doing
   / Want to make ball hitch attachment for the three point lift, Any made? #8
Thank you
I liked this design so much that I bought one! :)
The top receiver makes it very versatile.
Got it from: OMNI Mfg LLC
   / Want to make ball hitch attachment for the three point lift, Any made? #9
   / Want to make ball hitch attachment for the three point lift, Any made? #10
2017 Peterbilt 567 Tri-Axle Dump Truck (A48081)
2017 Peterbilt 567...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A51039)
2012 Freightliner...
2022 Chevrolet Tahoe FL SUV (A48082)
2022 Chevrolet...
2012 BMW 528i xDrive AWD Sedan (A48082)
2012 BMW 528i...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
